ST10000DM003 1CH162-512
March 4th, 2020, 15:19
Client says ROM and PCB original .
no strange sound. Drive stuck busy mode.
tried with donorpcb writed rom to donor pcb. same .
Unlocked firmware. Same
blocked H0 same (also h1 same)
terminal log;
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
Trans.
Spin Up
SpinOK
TCC:001B
PreampFaultStatus = 0084
SIM Error 1002 LBA 00000000000398AF FD FCFFF3FF
RW Error C4440080
(P) SATA Reset
SIM Error 1002 LBA 00000000000352F6 FD FC37F30A
RW Error C4440080
SimErrorCode = 00001002, RWErrorCode = C4440080
The Registry is corrupt.
LED:000000BD FAddr:00006454
Rst 0x40M
RW Error C4440080
SIM Error 1002 LBA 0000000000039FBA FD FCFFF3FF
RW Error C4440080
Terminal log
Terminal.rar
(365 Bytes) Downloaded 535 times
ROM
Data-W1D43ATH-2003041401.rar
(195.78 KiB) Downloaded 543 times
I need advices
Is it head issue ?? ( I dont guess that )
Re: ST10000DM003 1CH162-512
March 5th, 2020, 7:16
Is your drive's s/n W1D43ATH ?
March 5th, 2020, 9:34
northwind wrote:Is your drive's s/n W1D43ATH ?
Yes. I have checked that before.
I have tried virtual start procedure.
Power of on. Terminal stuck after press exchange command. .
Terminal log write just "redy" . Stopping .
If press ctrl -z
Same error log as posted before above
March 6th, 2020, 5:28
ST10000DM003 1CH162-512 Wrong
my drive ST1000DM003 1CH162-512
CC47
SN: W1D43ATH
I need virtual start loader - 3D file. using MRT
March 7th, 2020, 12:23
Here virtual3d from ST1000DM003-1CH162-CC47
F3-58-CC47Virtual3D.rar
(508.83 KiB) Downloaded 592 times
March 7th, 2020, 13:52
Change the heads ^
March 7th, 2020, 14:07
it is able to load some of the fw from the sa, but obviously there are some (30A for example) it cannot read. Heads are probably good, main sa head at least.
March 7th, 2020, 15:40
siamak5561 wrote:Here virtual3d from ST1000DM003-1CH162-CC47
thx
cpm1993 wrote:PreampFaultStatus = 0084
Change the heads ^
pepe wrote:it is able to load some of the fw from the sa, but obviously there are some (30A for example) it cannot read. Heads are probably good, main sa head at least.
2 different comment...
I have got MRT Remote support. Tecnician tried to solve. but said need short circiut to get T> level.
I have tried so many. But cannot. (I am not experienced about short circiut.)
And MRT told Would be necessary change head.
I think head is ok . So drive working so well..
Searched forums and google. Not much info about this situation.
I am thinking about , would give the drive to more experienced DR company . So I wont try head swap . Hate Seagate
March 7th, 2020, 18:21
i built some special loaders for such situations and also have instrumentation to check heads individually, which is pretty much basic thing when i want to diagnose a problem properly.
I like seagate. sorry :)
leave me a pm if you consider shipping it.
March 8th, 2020, 3:47
pepe wrote:i built some special loaders for such situations and also have instrumentation to check heads individually, which is pretty much basic thing when i want to diagnose a problem properly.
Thanks for advice but client wont accept overseas solutions about cost.
March 8th, 2020, 9:48
i am not overseas... but of course the price range may differ...
March 8th, 2020, 14:44
pepe wrote:i am not overseas... but of course the price range may differ...
March 11th, 2020, 16:05
bana getir bakayım.
sultangazi deyim..
0505 403 35 80
March 12th, 2020, 15:48
mikail13 wrote:bana getir bakayım.
sultangazi deyim..
0505 403 35 80
Istanbul'da değilim.
March 9th, 2022, 2:42
HddDonorMarket,
March 9th, 2022, 6:24
Like Same but headmap Edit solved
https://forum.hddguru.com/viewtopic.php ... us#p292763
https://forum.hddguru.com/viewtopic.php ... r+1002+LBA
March 9th, 2022, 7:19
Just try this
ST1000DM003-W1D43ATH-2003041401.rar
(873.46 KiB) Downloaded 350 times
