Re: WD Charger ROM fault / Encrypted data with donor ROM.
January 7th, 2022, 13:18
I confirmed that all the ROYL modules in SA module 0x129 are byte-for-byte equivalent to those modules which I extracted from the ROM. The only minor difference is the SA location of module 0x01 in module 0x20B.
Also, if I strip the leading 0x200 bytes from SA module 0x109, it compares byte-for-byte with the first half of the ROM until the end of the code section.
March 30th, 2022, 5:51
fzabkar, hello sir,
I have one palmer drive when i start with pc300 it shows
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 512
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 1024 Kb
Flash ROM dir reading................... : Ok (Active)
Flash ROM dir reading (Ext)............. : Ok
Modules directory address............... : 163 238
Module 02 access........................ : Granted
SA SPT.................................. : 0
ROM Modules:
ROM version............................. : 02.1AP
ROM F/W version......................... : Module ID 4F reading error Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Overlay F/W version..................... : 02.1AP
Servo F/W version....................... : 01.3C
Head Map Reading Error.................. : Module ID 0A reading error Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Relocations............................. : 0 (0)
i have tried 2 different rorm with same rom rev but still unable to get id. I think its problem with currupt rom .Can you pls help about this.I have done modules search within sa and found modules also module dir.there it shows 01 mod directory +m 163238 and with+ sign 726697. i have tried change dir address in sa region editor.but still id or dir not access.than i have tried mod 109 recover from sa image n recover 4f and 0a from rom image module 109.but still nothing happen.no dir accress.So pls look in to matter if possible.
log.log
(2.2 KiB) Downloaded 298 times
March 30th, 2022, 6:21
There are a number of very similar posts on the pc3K forum, although having numerous talents I don't think fzabkar is clairvoyant and will need the rom to check it :roll:
