 Post subject: HDD Seagate ST500DM002 500Gb LED:00000047 FAddr:FFFFFFFE
PostPosted: April 20th, 2022, 2:09
hi everybody, HDD Seagate ST500DM002 500Gb freezes during operation and after that it is no longer detected in the BIOS Connected it to the terminal and it began to give an error LED:00000047 FAddr:FFFFFFFE When the contacts are closed, it issues RECOV Servo Op=0155 Resp=0005 and then LED:00000047 FAddr:FFFFFFFE I need information from the disk, please tell me what else can be done?
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-001F
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MCMainPOR: EXCEPTION: MCMT PRI copy corrupt
MCMainPOR: MCMT SEC copy valid
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 00000000
[RSRS] 0000
ProcessRWError -Read- at LBA 0000000000000002 Sense Code=40000087
ProcessRWError -Read- at LBA 0000000000000026 Sense Code=40000087
ProcessRWError -Read- at LBA 0000000000000029 Sense Code=40000087
ProcessRWError -Read- at LBA 000000000000002B Sense Code=40000087
ProcessRWError -Read- at LBA 000000000000002D Sense Code=40000087
ProcessRWError -Read- at LBA 0000000000000030 Sense Code=40000087
ProcessRWError -Read- at LBA 0000000000000034 Sense Code=40000087
ProcessRWError -Read- at LBA 0000000000000036 Sense Code=40000087
ProcessRWError -Read- at LBA 000000000000003F Sense Code=40000087
ProcessRWError -Read- at LBA 0000000000000046 Sense Code=40000087
ProcessRWError -Read- at LBA 00000000000000D2 Sense Code=40000087
ProcessRWError -Read- at LBA 00000000000000D9 Sense Code=40000087
ProcessRWError -Read- at LBA 00000000000000DF Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00000000000000DF!
Reconstruction: Completed 0: HeadPtr was unwritten
[MCMTWS]
Rst 0x40M
Spin Up
TCC-001F
 Post subject: Re: HDD Seagate ST500DM002 500Gb LED:00000047 FAddr:FFFFFFFE
PostPosted: April 21st, 2022, 5:04
MCMainPOR: EXCEPTION: MCMT PRI copy corrupt <<<---------- this.
PostPosted: April 21st, 2022, 20:26
most probably a head/surface problem too, AltList may be full as well...
Users browsing this forum: Google [Bot] and 240 guests
