Hello
I have a problematic HDD.
MDL: ST500DM009-2F110A (COMPUTE)
Family: Pharaoh Oasis
After this HDD is ready, if I do the next thing, it becomes BSY.
ROM Tech patched. However, when entering the utility in PC-3K, SA cannot be read. (Redynes timeout (10000))
Module backup was performed through the terminal.
And I did a translator regeneration.
Now, If HDD is ready and trying to access the sector at the same time, it succeeds, but only the very front part is accessed.
However, the first symptoms did not change.
still BSY
ATA(indirect) is also not possible.
Help plz
thanks
Boot 0x20M
SpinUp
Trans
Tech Unlock Handshake: 0x9A1C3529
Reply:
Rst 0x20M Thermistor Temp 0017
2Sync:01 0E
2Sync:01 0E
2Sync:01 0E
2Sync:01 0E
2Sync:01 0E
(P) SATA Reset
LD: Size:00000028 HBlocks:0000 Size:002BCA77 HBlocks:0031 Size:00281205 HBlocks:0031 FlashRestore 00000000 00000028 14D7
PP: Size:0000B400 HBlocks:0000 FlashRestore
PVTSize: 00009C08 CompSize: 00000146 DeCompSize: 00009C08 00000000 00000146 37A7
2Sync:00 04
DSP06C3
