 Post subject: HGST DC HC550 18TB WUH721818ALE6L4 bricked?
PostPosted: May 13th, 2022, 19:58
I just recently got a bunch of HC550 18TB non-sed 512e/4k SATA drives. I wanted to convert these to 4k/4k for use in ceph. So I went on my merry way and downloaded hugo and did;
./hugo f -b 4096 -m WUH721818ALE6L4
Now this turned out to be a bit of a mistake as it started formatting all 12 drives in the server in question. Which initially was fine, but the format took forever, and unfortunately I lost ssh connection to the server and hugo subsequently crashed. Only later I learned I should have used --fastformat.
A good 24hr later, I powercycled the server. And now, unfortunately none of the disks seem to work anymore. I can still see then with hugo s:
# ./hugo s
     Manuf.       Model               Serial                Interface       Capacity  Type  Firmware
  1) Seagate      ST9146853SS         6XM1C4EM              SAS             146   GB  HDD   YS0D
  2) Seagate      ST9146853SS         6XM26BYY              SAS             146   GB  HDD   YS0C
  3) HGST         WUH721818ALE6L4     3RG72Y4A              SATA            18000 GB  HDD   PCGAW232
  4) HGST         WUH721818ALE6L4     3RG6X5BA              SATA            18000 GB  HDD   PCGAW232
  5) HGST         WUH721818ALE6L4     3RG6HYBA              SATA            18000 GB  HDD   PCGAW232
  6) HGST         WUH721818ALE6L4     3FG8DL1T              SATA            18000 GB  HDD   PCGAW232
  7) HGST         WUH721818ALE6L4     3RG71YWA              SATA            18000 GB  HDD   PCGAW232
  8) HGST         WUH721818ALE6L4     3RG6EYTA              SATA            18000 GB  HDD   PCGAW232
  9) HGST         WUH721818ALE6L4     3RG5Z48A              SATA            18000 GB  HDD   PCGAW232
10) HGST         WUH721818ALE6L4     3FG7X4TT              SATA            18000 GB  HDD   PCGAW232
11) HGST         WUH721818ALE6L4     3RG7D82A              SATA            18000 GB  HDD   PCGAW232
12) HGST         WUH721818ALE6L4     3RG6H6NA              SATA            18000 GB  HDD   PCGAW232
13) HGST         WUH721818ALE6L4     3RG742ZA              SATA            18000 GB  HDD   PCGAW232
14) HGST         WUH721818ALE6L4     3RG71UXA              SATA            18000 GB  HDD   PCGAW232
But they are unresponsive in regards to formatting them, and if the MegaRAID controller tries to configure them as non-raid devices, they are immediately marked as failed until reboot.
Trying to format one yields the following result:
# ./hugo f -b 4096 --fastformat --danger-zone -s 3RG71UXA
Format device on 1 Device(s)...
Failed: Format command Failed on device 3RG71UXA.
        Device will not be formatted.
Any advice at all would be greatly apprechiated.
Thanks!
Best,
Rune
 Post subject: Re: HGST DC HC550 18TB WUH721818ALE6L4 bricked?
PostPosted: May 14th, 2022, 8:52
I should add, whenever I actually try to do an operation like upgrade firmware, erase disk or similar, I get this 77830 error. Anyone seen this before or has any idea what it might mean?
Another thing is that I am unable to configure the drives in the controller, so that the OS can see them.
# ./hugo e -t -s 3RG71UXA
        ******************************** WARNING **********************************
           This will erase data on the specified devices.
           These devices might include your boot device and it won't be protected.
           This will not work on devices currently running a self-test.
                Are you sure you want to erase these devices? (Y/N) y
        Device: 3RG71UXA partition table erase FAILED: Error code not mapped: -77830
Best,
Rune
PostPosted: May 14th, 2022, 10:20
I don't know what 100% will help you, but can you try format with ordinary HBA?
PostPosted: May 16th, 2022, 13:57
Right. So attaching the disk to a plain SATA controller allowed me to continue the drive format where it left off when it was rebooted.
Thanks for the advice.
Regards,
Rune
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 166 guests
