 Post subject: ST1000VX005-2EZ102 CV11 - Reading in Pattern
PostPosted: June 3rd, 2022, 7:55
ST1000VX005-2EZ102 F/W: CV11 in Mrt detected as Luxorlite10 but can't read ROM in BootCode.
If i select LuxorLite then can read and Patched(Luxorlite10) and write(Luxorlite).
HDD comes with 2 clicks and Spin Down. After changing headmap to 01 01 hdd started and ID with full Capacity.
When i try to image in DE, it reads in particular pattern like in the Picture ( Can't describe so only Picture)
Success and Skipped areas are in Pattern. (RED Black Yellow maps Cleared). Reading Speed is also good in those success Area.
This already happened in 3 cases of the same family, In all these 3 only H1 (H0 Bad) is used to start hdd.
H0 is bad in SA but read in UA.
Head change may solve the issue, but why it reads and skips in particular manner
 Post subject: Re: ST1000VX005-2EZ102 CV11 - Reading in Pattern
PostPosted: June 3rd, 2022, 17:37
I am expecting a answer here -> https://forum.hddguru.com/viewtopic.php?f=1&t=42196 . A Very bad habit asking for advice and solving it and never letting the forum know whats what ,If members agree to this i expect none will answer this post of yours because you asked for advice , solved it and ran off ,Sorry to be straightforward and blunt .
PostPosted: June 4th, 2022, 0:30
In This case
Nothing special
Just Used Mrt T2 Editor and uploaded to RAM
All sectors Accessed without any issue.
Is any secret in This.
If i did anything special i surely i will share.
I asked Amarbir[CDR-Labs] in your case of 4TB in PM with my whatsapp but u did not care about that PM then ???
PostPosted: June 4th, 2022, 5:57
gps31 wrote:
In This case
Nothing special
:mrgreen: ,
We are not fighting with you ,We were just asking you to write the solved solution ,Anyways my case are very different ,I will surely make a video and share with everyone here
PostPosted: June 4th, 2022, 9:00
Is there any solution for this my seagate case.
PostPosted: June 4th, 2022, 10:31
Well,
What are you wanting to ask ,That if you set headmap in rom as 01 01 hdd boots and then you can read head 00 and 01 both ? why is this happening,is this your question
PostPosted: June 4th, 2022, 10:37
Amarbir[CDR-Labs] wrote:
Well,
Read Length and Skip Length are Particular Pattern ( From image u can see that)
PostPosted: June 4th, 2022, 11:17
H1 zones are being read and H0 zones are being ignored.
The images show the reading of only one head.
VEXUS Data Recovery
PostPosted: June 4th, 2022, 12:34
True ,
i am also of the same opinion as you are .
PostPosted: June 4th, 2022, 13:21
I suspect that H0 is simply bad, that's why you see a bad pattern
And the head map you built for the drive is likely incorrect, that's why you THINK that H0 can ready but it actually cannot.
Users browsing this forum: No registered users and 73 guests
