 Post subject: UnKnown 223.57 gb Not Initialized
PostPosted: May 31st, 2022, 5:15
Hi
I have SSD 240GB kingstone . I got error (UnKnown 223.57 gb Not Initialized).
I did Intial to SSD but fail.
Pls your advice to recover my data.
Best Regards
 Post subject: Re: UnKnown 223.57 gb Not Initialized
PostPosted: May 31st, 2022, 16:34
Can you retrieve a SMART report? If not, then the SSD most probably has a "firmware" problem.
PostPosted: May 31st, 2022, 17:06
May be solved easily. Take this to your data recovery local shop. Should be a minimal fee.
PostPosted: June 6th, 2022, 12:55
How to upgrade the frimeware ?
PostPosted: June 6th, 2022, 16:09
I do not think fzabkar implied for you to update the firmware. Not if you need the data back.
