Hello there.
I'm using HDDLiveCD trying to clone this drive and didn't know after 10 days that it was a way to speed up the process on slow WD drives. I'd tried again from phase 1 in Direct AHCI mode, hiding the port of the drive on boot (As shown on one of HDDSuperclone youtube videos). I'd achieved a 92% of progress on phase 1, but now every time pops-up a window saying that
"Failed to perform identify device command" (log1). When I've to select the source drive sometimes appears as busy, but when trying again it appears with his serial.
I don't know If this is the proper workflow of HDDSuperclone, but every time I try to resume my project from the same 92%, but using another port or mode, all the
information on the interface is zeroed out (log2). When I start the process, in about 10 seconds all the phases finishes but with no progress at all.
Thanks in advance from any help you can bring!
(Backstory: An acquaintance of mine bring me this disc with some important information, after I tell him to go with someone professional on data recovery. He didn't listen and here am I.)
File comment: Log 1: Can't Identify Source Drive
save03.txt [50.96 KiB]
Downloaded 261 times
File comment: Log 1: Interface Showing some progress
File comment: Log 2: UI is zeroed out after selecting source
save03B.txt [54.18 KiB]
Downloaded 241 times
I'd edited this log to add the size again to see if it does something, but keeps doing the same thing
File comment: Log 2: UI zeroed out
