 Post subject: WD My Passport 1TB - unlock in WD Drive utility not working
PostPosted: September 8th, 2022, 14:21
Dear HDDGuru Community,
I have a strange case of a newer WD My Passport protected with password via WD Drive utility. After plugging in, the drive shows the window of WD Drive Unlock to enter the password, the utility refuses any password. I have the correct password.
It is a newer Palmer family. Would it make sense to convert the drive from USB to SATA (using the unlocked PCB) and then read the encrypted image via PC3K. Would it be possible then to decrypt it via standard solutions? Have anyone of you encountered problem like this?
Thanks in advance,
Oliver
MACROFER - data recovery
 Post subject: Re: WD My Passport 1TB - unlock in WD Drive utility not work
PostPosted: September 11th, 2022, 15:28
If it’s one of the later Palmer drives, it has hardware encryption via the MCU so can only be decrypted using the USB PCB.
PostPosted: October 8th, 2022, 6:07
this adapter without soldering can help you to decrypt data .
Skype:jieshan.weng
Ph(whatsapp):+8613764461998
https://www.facebook.com/datarecoveryChina
http://www.datarecovery-china.com
Users browsing this forum: Google [Bot] and 238 guests
