 Post subject: BIOS chip mix-up
PostPosted: October 31st, 2022, 9:29
Dear all,
I had someone transfer the BIOS chip to a donor board(2060-771961-001 rev A) but I suspect there was an error. I read the dump files with CH341A and one of the files contain the exact model of my drive. (WDC WD10JMVW-11AJGS1) The other contains the model of USB IC (INIC-3608)
I'd expect the one with INIC-3608 text string to be the U14 but I want to make sure before soldering.
Thanks.
 Post subject: Re: BIOS chip mix-up
PostPosted: November 1st, 2022, 3:56
No need to worry about U14
PostPosted: November 1st, 2022, 4:26
The problem is I don't know which chip to not worry about. :D
Do you think the one with HDD model string is U12?
PostPosted: November 1st, 2022, 11:52
islamm3rouf wrote:
one of them will spin disk up
this is ROM
other one will not
try with no problem
Thank you. The disk spins now but not recognized through USB. Replacement PCB is rev B. My original was rev A. Are they interchangeable?
PostPosted: November 3rd, 2022, 6:05
This is the ROM content I got by usin fzabkar's tool. Do you think my problem is ROM related?
Searching for LDSCs and verifying PCMBlocks ...
LDSC   LDSC    Att   PCMBlock          RAM         size      PCMBlk CS
Start  ID CS        Start -  End     address     RAM / ROM    Exp/Act
    0  5A C1   02     100 -  2477      127F0     2376  2376  A1FE A1FE   OK
   20  01 5B   0C    2478 -  4C4C   88800000     27D4  27D4    4C   4C   OK
   40  02 D5   01    4C4D -  CFA9          0 c   AB1C  835C    A4   A4   OK
   60  03 A9   01    CFAA -  D6A2      1179C c    8C0   6F8    65   65   OK
   80  04 02   03    D6A3 -  D89B      80220 c    2B0   1F8    40   40   OK
   A0  05 CC   03    D89C -  DA90   10157200 c    318   1F4    57   57   OK
   C0  06 FB   01    DA91 - 24C49   90349A00 c  1EA38 171B8    77   77   OK
   E0  07 94   01   24C4A - 3DCCE   90006E30 c  236AC 19084    FB   FB   OK
LDSC   = PM Loader Config String (32 bytes)
ID     = ID byte of LDSC (byte #0)
CS     = Checksum byte or word
Att    = Attributes
PCMBlk = Program Code Memory Block
Exp    = Expected checksum for PCMBLock
Act    = Actual checksum for PCMBLock
c      = compressed PCMBlock
size   = size of decompressed (in RAM) and compressed (in ROM) PCMBlock in bytes
ROYL directory module 0x000B found at 0x3FCD2
Active directory flag = 0x02
Identifying SA regions ...
Reg#    Reg size     Reg loc
0x00  0x00045600  0x00000000
0x01  0x00045600  0x0005C800
0x02  0x00045600  0x000B9000
0x03  0x00045600  0x00115800
Verifying ROYL modules ...
ID          Size (bytes)         Address    Checksum
dir   hdr        dir       hdr
0001  N/A    00004000  N/A        00019BAB             N/A
000A  OK     0000003E  00000200   0003F000   00000000  OK
000B  OK     00000169  00000200   0003FCD2   00000000  OK
020B  OK     00000169  00000200   0003ECD2   00000000  OK
0030  OK     00000400  OK         0003F8D2   00000000  OK
0047  OK     00000400  OK         0003F4D2   00000000  OK
000D  OK     00000094  00000200   0003F03E   00000000  OK
004F  OK     00000400  OK         0003F0D2   00000000  OK
ROYL directory module 0x020B found at 0x3ECD2
Active directory flag = 0xFE
0x00  0x0002CA60  0x00000000
0x01  0x0002CA60  0x0005C800
0x02  0x0002CA60  0x000B9000
0x03  0x00000000  0x00000000
0x04  0x00000000  0x00000000
0x05  0x00000000  0x00000000
0x06  0x00000000  0x00000000
0x07  0x00000000  0x00000000
dir   hdr        dir       hdr
0001  N/A    00004000  N/A        00000000             N/A
000A  OK     0000003E  00000200   0003E000   00000000  OK
0030  FFFF   00000400  01FFFE00   0003E8D2   FFFFFF00  BAD
0047  FFFF   00000400  01FFFE00   0003E4D2   FFFFFF00  BAD
000D  OK     00000094  00000200   0003E03E   00000000  OK
004F  OK     00000400  OK         0003E0D2   00000000  OK
dir  -  Module ID/Size as reported in directory module (0x20B or 0x0B)
hdr  -  Module ID/Size as reported in module's header
N/A  -  Not Applicable
BAD  -  Module has invalid checksum. This may be due to non-existent module.
ROM modules saved to Flash_02\000Bmods and Flash_02\020Bmods
Active directory is 0x0B
Analysing active 0x0A module ...
Head map checksum (Expected / Actual) = 0x0000 / 0x0000 - OK
Number of heads (physical / in use) = 4/4
Head map #1 = 0x0F / 0b00001111
Head map #2 = 0x00 / 0b00000000
DCM = | Q | G J N V D H E
      : : : : : : : : : unknown
      : : : : : : : : top VCM
      : : : : : : : ACA
      : : : : : : bottom VCM
      : : : : : HSA
      : : : : media
      : : : preamp
      : : latch
      : base
      spindle motor
Analysing active 0x0D module ...
Firmware Version = 01.01A01
World Wide Name = 50014EE209153191
Model Number = WDC WD10JMVW-11AJGS1
Serial Number =
Analysing active 0x4F module ...
ROM version = 0006000M
Analysing active 0x47 module ...
Preamp values
0  033B3217
1  033B5515
2  02393418
3  023B3419
Microjogs
0  0000
1  0000
2  0000
3  0000
Head/Media DCM = NJ
PostPosted: November 3rd, 2022, 19:33
The ROM seems OK. The "BAD" ROYL modules are in the inactive directory. All the modules in the active directory are good.
PostPosted: November 5th, 2022, 10:30
Rarely it is a problem with the ROM or PCB in general on that model drive.
The problems with that model typically are:
-disk surface degradation (bad sectors)
-many bad sectors accumulation trigger firmware problems
-mechanical - reading heads
If the drive is recognized with correct capacity, then you could try cloning with ddrescue or hddsuperclone. They are the best you could do with software based tools a DiY at home (if the drive clones slowly, as in taking weeks, then it has firmware or mechanical issues).
Specialists use more advanced hardware cloning tools.
Users browsing this forum: Google [Bot] and 274 guests
