 Post subject: WD400JD-22JNA0 ROM REQUIRED
PostPosted: December 28th, 2022, 3:08
I have WD40 GB HDD
ROM and ROM MODULES required.
WD400JD-22JNA0
Please share if any one have it.
Thanks.
 Post subject: Re: WD400JD-22JNA0 ROM REQUIRED
PostPosted: December 28th, 2022, 13:10
It would be appropriate to provide the date of manufacture of the disc
This drive is Sabre53
Mikippp
ROM_0886C_01A8_WD800JD-75JNA0_07-JAN-2005.zip [123.71 KiB]
Downloaded 259 times
PostPosted: December 29th, 2022, 0:38
Mikippp
Thanks.
DATE - 27 NOV 2004
DCM - DSBANTJCA
PostPosted: December 29th, 2022, 5:00
you could like use a different version to access the SA and find out the native version from the modules...
PostPosted: January 2nd, 2023, 0:51
Thank you All for the support
Gained access to SA using different ROM Version and could solved the case
Thanks one again
PostPosted: January 2nd, 2023, 17:32
:beer:
