Post new topic Reply to topic  [ 88 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: ST3000DM001 1CH166-510 issue
PostPosted: December 24th, 2022, 5:01
ignore the skip count it is afaik cumulative, the key figures are the non tried/non trimmed , bad and obviously the Finished.
As I said you'll get a much better visual feel for the drive damage if you view the log file on hddscviewer. Looking back at your posts the drive appears to have ben timing out during background processes when you were copying files from it.
PostPosted: December 24th, 2022, 9:30
A fair enough, I'll probably have a look at it tomorrow or at least soon.
Thanks again :)
PostPosted: January 3rd, 2023, 1:45
I'm finally back, but just to say that I haven't done anything else yet as I kind of want a second opinion that it is safe to stop the recovery process and time to check the image.
I'm yet to run hddscviewer as I somehow overlooked that, but I'll do that asap.
Thanks again and Happy New Year :)
PostPosted: January 3rd, 2023, 5:05
It is a bit hard to advise coz i don't even know if the drive can still read anything or head(s) degraded...
If you want to be on the safe side, take a backup of the imaged data and start checking it using some logical recovery sw, (dmde, ufs explorer, rstudio... )
Now it would be good if you had filled the target drive with some pattern prior imaging, to identify files with problems. Dunno if these logical recovery progs can use the logs of hddsuperclone...
PostPosted: January 3rd, 2023, 5:13
So much of that just went over my head.
I'll make a copy of the image and try using hddscviewer and also see what happens if I mount it.
And if I come across issues I'll try dmde.
PostPosted: January 3rd, 2023, 20:10
HDDSuperClone can be used to fill the unrecovered areas of the destination with a fixed pattern with the mark fill option, so that the pattern could be searched for in files.
R-Studio supposedly introduced working with ddrescue and hddsuperclone sector maps about a year ago, although I am not able to test it as I only have a license for an old version.
http://www.hddsuperclone.com
Home of HDDSuperClone
PostPosted: January 3rd, 2023, 22:30
Nevermind about R-Studio sector maps, that feature is only available in the much more expensive technician version.
PostPosted: January 4th, 2023, 9:50
filling the unread areas is useful, thx for clarification. SubSonix should be able to identify corrupt files by that...
