 Post subject: WD20NMVW-11EDZS6 showing BSY
PostPosted: January 7th, 2023, 10:49
Hi all,
First time poster but a long time lurker - thanks for all the contributions which have helped me in the past!
I have a WD20NMVW-11EDZS6 USB drive pulled from a MyPassport enclosure.
The customer reports the drive has not been dropped or mishandled and simply stopped mounting recently.
I confirmed drive does not mount and shows zero capacity. All sounds normal.
I converted the board to SATA and tried to open in MRT but I am only getting BSY still. Also tried with a RapidSpar and it can also not communicate with the drive.
Any guidance would be appreciated. I've not dealt with many of this model before and when I have this symptom was not encountered.
Thanks!
snhc
 Post subject: Re: WD20NMVW-11EDZS6 showing BSY
PostPosted: January 8th, 2023, 22:42
Block MOD30; and use LDR load DIR and then inspect secondary translator.
PostPosted: January 8th, 2023, 23:02
Hmm, correction no secondary on Shrek LT. Check FW - do SA check. Disable relo and SMART in MOD02.
Users browsing this forum: No registered users and 76 guests
