WD Black 2 120GB + 1TB WDC WD1001X06X-00SJVT0
October 24th, 2016, 1:47
Hello. I need help with HD WD Black 2 120GB + 1TB
Original firmware is broken no possible read IC. I have its same model HDD if change 25Q16CL SOIC8 HDD detect data from SSD part 120GB but no from 1TB
part. Headers move up - down 3-4x and stop and again. How possible rebuild - repair firmware or where is problem ? 25Q16CL SOIC8-200.bin is from second
hdd. My firmware no possible read memory 25Q16CL its broken. WDC WD1001X06X-00SJVT0
Thank you.
25Q16CL SOIC8-200.rar
(869.66 KiB) Downloaded 876 times
Re: WD Black 2 120GB + 1TB WDC WD1001X06X-00SJVT0
October 24th, 2016, 11:44
I will help you If you can send it to me.
October 24th, 2016, 20:42
"drHDD" sent me contact ... example skype
October 24th, 2016, 22:44
Just some observations ...
Offsets 0 - 0x7FFFF appear to contain the usual ROM code plus 7 ROYL modules (0A, 0B, 20B, 30, 47, 0D, 4F) at the end.
The space after offset 0x80000 appears to be set aside for backups of various SA modules, including 0x01 (offset 0xEC000), 0x02 (offset 0xF0000), and 0x11 (offset 0xF0A00). Module 01 has an alias of 0x0F01 in the directory, but its actual ID in the ROM is 01.
Here is the directory in mod 0B:
Offset(h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 11 12 13 14 15 16 17 18 19
00000000  1A 04 01 00 20 00 0F 18 90 00 22 99 01 00 22 99 01 00 00 00 00 00 00 00 00 00
0000001A  1A 01 0A 00 3E 00 00 19 00 00 00 F0 07 00 00 00 00 00 00 00 00 00 00 00 00 00
00000034  1A 01 0B 00 41 04 00 19 00 00 D2 F8 07 00 00 00 00 00 00 00 00 00 00 00 00 00
0000004E  1A 01 0B 02 41 04 00 19 00 00 D2 E8 07 00 00 00 00 00 00 00 00 00 00 00 00 00
00000068  1A 01 30 00 00 04 00 19 00 00 00 D0 07 00 00 00 00 00 00 00 00 00 00 00 00 00
00000082  1A 01 47 00 00 04 00 19 00 00 D2 F4 07 00 00 00 00 00 00 00 00 00 00 00 00 00
0000009C  1A 01 0D 00 94 00 00 19 00 00 3E F0 07 00 00 00 00 00 00 00 00 00 00 00 00 00
000000B6  1A 01 4F 00 00 04 00 19 00 00 D2 F0 07 00 00 00 00 00 00 00 00 00 00 00 00 00
000000D0  1A 01 0C 00 0B 00 00 19 00 04 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00
000000EA  1A 01 03 00 8E 00 00 19 00 04 00 16 08 00 00 00 00 00 00 00 00 00 00 00 00 00
00000104  1A 01 40 00 80 01 00 19 00 04 00 32 09 00 00 00 00 00 00 00 00 00 00 00 00 00
0000011E  1A 01 4D 00 01 00 00 19 00 04 00 32 0C 00 00 00 00 00 00 00 00 00 00 00 00 00
00000138  1A 01 49 00 0E 00 00 19 00 04 00 34 0C 00 00 00 00 00 00 00 00 00 00 00 00 00
00000152  1A 01 4A 00 11 00 00 19 00 04 00 50 0C 00 00 00 00 00 00 00 00 00 00 00 00 00
0000016C  1A 01 36 00 16 00 00 19 00 04 00 72 0C 00 00 00 00 00 00 00 00 00 00 00 00 00
00000186  1A 01 29 00 09 00 00 19 00 04 00 9E 0C 00 00 00 00 00 00 00 00 00 00 00 00 00
000001A0  1A 01 32 01 40 00 00 19 00 04 00 B0 0C 00 00 00 00 00 00 00 00 00 00 00 00 00
000001BA  1A 01 00 D0 01 00 00 19 00 04 00 90 0E 00 00 00 00 00 00 00 00 00 00 00 00 00
000001D4  1A 01 01 D0 01 00 00 19 00 04 00 92 0E 00 00 00 00 00 00 00 00 00 00 00 00 00
000001EE  1A 01 02 D0 01 00 00 19 00 04 00 94 0E 00 00 00 00 00 00 00 00 00 00 00 00 00
00000208  1A 01 03 D0 01 00 00 19 00 04 00 96 0E 00 00 00 00 00 00 00 00 00 00 00 00 00
00000222  1A 01 04 D0 01 00 00 19 00 04 00 98 0E 00 00 00 00 00 00 00 00 00 00 00 00 00
0000023C  1A 01 05 D0 01 00 00 19 00 04 00 9A 0E 00 00 00 00 00 00 00 00 00 00 00 00 00
00000256  1A 01 06 D0 01 00 00 19 00 04 00 9C 0E 00 00 00 00 00 00 00 00 00 00 00 00 00
00000270  1A 01 27 01 01 00 00 19 00 04 00 9E 0E 00 00 00 00 00 00 00 00 00 00 00 00 00
0000028A  1A 01 01 0F 20 00 00 19 00 04 00 C0 0E 00 00 00 00 00 00 00 00 00 00 00 00 00
mod 01 (= 0F01) ^^^^^ ^^^^^             ^^^^^^^^ ROM offset 0xEC000, size 0x20 x 0x200
000002A4  1A 01 02 00 05 00 00 19 00 04 00 00 0F 00 00 00 00 00 00 00 00 00 00 00 00 00
         mod 02 ^^^^^ ^^^^^             ^^^^^^^^ ROM offset 0xF0000, size 0x5 x 0x200
000002BE  1A 01 11 00 40 05 00 19 00 04 00 0A 0F 00 00 00 00 00 00 00 00 00 00 00 00 00
         mod 11 ^^^^^ ^^^^^             ^^^^^^^^ ROM offset 0xF0A00, size 0x540 x 0x200
000002D8  1A 01 11 04 E2 00 00 19 00 04 00 8A 19 00 00 00 00 00 00 00 00 00 00 00 00 00
000002F2  1A 01 50 00 05 00 00 19 00 04 00 4E 1B 00 00 00 00 00 00 00 00 00 00 00 00 00
0000030C  1A 01 51 00 05 00 00 19 00 04 00 58 1B 00 00 00 00 00 00 00 00 00 00 00 00 00
00000326  1A 01 52 00 05 00 00 19 00 04 00 62 1B 00 00 00 00 00 00 00 00 00 00 00 00 00
00000340  1A 01 53 00 05 00 00 19 00 04 00 6C 1B 00 00 00 00 00 00 00 00 00 00 00 00 00
0000035A  1A 01 81 00 09 00 00 19 00 04 00 76 1B 00 00 00 00 00 00 00 00 00 00 00 00 00
00000374  1A 01 5C 00 24 01 00 19 00 04 00 88 1B 00 00 00 00 00 00 00 00 00 00 00 00 00
0000038E  1A 01 40 01 01 00 00 19 00 04 00 6A 1E 00 00 00 00 00 00 00 00 00 00 00 00 00
November 3rd, 2016, 15:51
fzabkar, Hello. Looking for good hardware for repair or rebuild firmware hdd
November 3rd, 2016, 16:27
Sorry, I can't see any DIY solution. :-(
February 18th, 2023, 23:16
can i just run on ssd via pcb only? thx
