Hello everyone, I hope someone in this community could help me to understand what's wrong with my old hard drive
Forewords:
All sensible data has been already backuped, so I have no reason to contact an expensive recovery service. I'm trying to do my best only for fun, but only in the last two months I'm discovering how tricky is an HDD (not mentioning the mechanical aspect)
The HDD is quite old (2012) and I've already replaced it with an SSD and moved as secondary disk.
The HDD started to desappear occasionally at latest boots requiring a reboot to be correctly recognized by bios, so its failure wasn't a surprise.
1. The disk never sounded weird, so I thought that replacing the pcb could restore the drive. Of course I was wrong.
2. Searching on this and other forums I tried to apply the "Busy bug" procedure, I stopped after clearing the SMART statistics because I realized that I was on the wrong direction and I could only make it worse
3. While waiting for another ST1000DM003 (used but healthy), eventually to sacrify as "donor", I studied better the Seagate Terminal and I gathered several informations (attached)
Now I'm supposing that the fw Is not loaded, this could explain why the Terminal is unlocked, differently for the "donor" HDD, but I need a confirmation from some expert.
The P-List is readable and huge.
If I'm right and the firmware is not loaded, the next question will be: can I upload the firmware into the ram directly from terminal or at least try to rewrite it? There's a free-ware/trial tool for that?
Thank you in advance for your attention, follows an extract from the console activity attached to the post,
Alessio
from Power On:
Boot 0x40M
Spin Up
Trans.
Spin Up
(P) SATA Reset
ASCII Diag mode
F3 T> (Ctrl + i)
LuxorPlus Rev: 0203; No Host; SpdLimit: 6.0GbMax; SSC: Yes; LED: No; StagSpinByp: Yes;
SATA Block Registers
ATA
800DC000: 0001 0000 0000 0000 0001 0400 0000 0000
800DC010: 0000 0000 4400 0480 0040 0000 0000 0400
800DC020: 0080 0000 0010 0210 0000 0000 0000 0000
800DC030: 0000 E60B 0000 0000 0000 0000 0000 0000
800DC040: 0000 0000 0800 0000 0000 0000 FFFF 003F
800DC050: 4795 57A5 CE2D 0000 0000 0000 0000 0000
80007FD0: 00000000 00000000 00000000 00000000
80007FE0: 00000000 00000000 00000000 00000000
80007FF0: 00000000 00000000 00000000 00000000
Hardware Phy Event Counters
00000000: 0000 0000 0000 0000 0000 0000 0000 0000
00000010: 0000 0000 0000 0000 0000 0000
R_ERR on RX FIS Non-data: 00000, Data: 00000
R_ERR on TX FIS Non-data: 00000, Data: 00000
F3 T> (Ctrl + a)
Package Version: GPG17B.CCD4.AM0247.CC43 , Package P/N: 100711986, Package Global ID: 00188399,
Package Build Date: 07/19/2012, Package Build Time: 09:41:47, Package CFW Version: GPG1.CCD4.00463044.00188399,
Package SFW1 Version: B7E6, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 07190941, CustomerRel: CC43, Changelist: 00463044, ProdType: GPG1.CCD4, Date: 07/19/2012, Time: 094147, UserId: 00188399
Servo FW Rev: B7E6
RAP FW Implementation Key: 16, Format Rev: 0004, Contents Rev: 71 01 07 00
TCG IV Version: n/a
F3 T>J
CAP:
(P1=00) Validation Key: 00000020
(P1=01) HDA Serial Number: S1D4HNPM
(P1=02) PCBA Serial Number: 0000M3041D8N
(P1=03) PCBA Part Number: Invalid
(P1=04) Head Count: 02
(P1=05) Node Name Validation Key: 01
(P1=06) Node Name: 50 00 C5 00 52 00 2B 53
(P1=07) Product Family ID: 58
(P1=08) Product Family ID: 06
(P1=09) PCBA Build Code: Invalid
(P1=0A) ASIC Info:
FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FF FF FF FF FF FF FF FF FF FF FF FF 00
(P1=0B) Firmware Key: FF FF FF FF FF FF FF FF FF FF FF FF FF FF
(P1=0C) Firmware Key Checksum: FFFF
(P1=0D) Date of Manufacture: 08042012
(P1=0E) Destroked Buf Size Index: 03
(P1=0F) Final Mfg Op: Invalid
(P1=10) Final Mfg Erc: Undefined
(P1=11) System Area Prep State: FE
(P1=12) SPT Auto Run Delay: 00
(P1=13) Reserved: 00
(P1=14) Checksum: FFFF
(P1=15) External Model Number: ST1000DM003-1CH162
(P1=16) Internal Model Number: ST1000DM003-1CH162
(P1=17) IDEMA Capacity: 0000000074706DB0
(P1=18) Reserved1:
F3 T>/7
F3 7>X
Head 00 Resistance 0168
Head 01 Resistance 013F
- Attachments
seagate2.log
- F3 Terminal log
- (3.84 MiB) Downloaded 377 times
