 Post subject: WD80EFAX-68KNBN0
PostPosted: May 18th, 2023, 15:27
Is there any way to access SA on those HGST drives?
The drive spin up heads moves from parking area and the drive continue spinning (ABRT).
Thanks in advance.
 Post subject: Re: WD80EFAX-68KNBN0
PostPosted: May 18th, 2023, 15:34
Is there a way to access SA - yes.
Are there commercial tools available - no.
Outsource it.
PostPosted: May 18th, 2023, 15:47
Outsource it.
Thanks for the quick response Mr.Artem.
Is this a typical issue of head/s failure? Or is it really a FW problem?
PostPosted: May 18th, 2023, 17:12
It can be both. It is very common, yes.
PostPosted: May 18th, 2023, 17:18
Thanks a lot Mr. Artem. Much appreciated.
I will let the customer contact you directly.
I always recommend your company for this kind of advanced jobs
Thank you.
