 Post subject: Fujitsu MPE3064AT
PostPosted: June 15th, 2005, 13:26
Hi Guys,
I'm looking for some help with a Fujitsu MPE3064AT.
It's spinning fine and no noises, drive is jumpered in master mode.
Universal utility - parameters of drive are not detected
The State Register shows a red LED on ERR
DRDY, DSC & DRQ are yellow
Error register shows RED on ABRT
Fujitsu MPE Utility: "Disk drive logical parameters are not defined, using default"
Then choose the correct model and get the following errors:
Error Reading Table HS
Error Reading Table TS
IDNF shows RED in the Error Register
Error Reading Table PL, TS, HS, SN, FI, CI, SM, SU
Any ideas?
Thanks,
CK
 Post subject:
PostPosted: June 20th, 2005, 20:32
Have you tried HS and fw checking ??
Users browsing this forum: No registered users and 83 guests
