 Post subject: Toshiba external drive HDTC605EK3A1 - Can't access content
PostPosted: September 23rd, 2023, 7:43
Its light turns on when I plug it in, it gets detected by Windows, but I can no longer access its content. When I try to I either get an error message about device not being found or "You Need to Format the Disk in Drive Before You Can Use It". Of course, there's a notable lag before these messages pop up.
This only happened since yesterday I tried plug it in after 5 years of not using it. I plugged it in in a rather inclided position, maybe 30 degrees, and the disk started making some "struggling" noises. These noises stopped once I put it in a flat surface (my own hand) and then the content of the drive showed up on screen. I was able to browse it for a few seconds, but then the window disappeared as if I had unplugged it even if I didn't.
After that, I only get what I have described in the first paragraph.
Is there a way I can fix that?
Users browsing this forum: Google [Bot] and 47 guests
