 Post subject: recovery of MAC HFS+ file system
PostPosted: October 4th, 2007, 10:53
I have recenty pulled an image from a failed MAC drive. My recovery equipment is all Windows based (NTFA and FAT). I have tried to copy the recovered RAW image to another drive and connect that to a working Mac G4 via USB enclosure, however, the Mac OS (OS-X) says the drive is not of a recognizable file system and either needs repaired or initialized.
I can scan the image with R-studio which gives me a bunch of files sorted by type, but they have incorrect filenames (all sequential numbers).
What is the typical way to get the data back to a usable format (with the correct names)? I have read about a program called TransMac. Anyone used this? Could this do what I need? Thanks
 Post subject: Re: recovery of MAC HFS+ file system
PostPosted: October 4th, 2007, 10:54
You can use winhex forensic (on a pc) or data rescue (on a mac).
For macs i prefer data rescue.
Best regards,
Dobre
Murphy was an optimist
PostPosted: October 4th, 2007, 15:48
if you have cloned byte for byte and mac doesn't recognise, then the file system is corrupt ..afaik R-studio doesn't read hfs+..
Winhex will with the correct template , Transmac works well, Stellar works , and there are a couple more ..
You can also try a Linux Live CD , if I'm not mistaken it has Hfs+ support.
sometimes you have to physically repair the file system... if you do , Apple has very good documentation of the HFS+ layout ..
PostPosted: October 4th, 2007, 19:43
Data Rescue Mac is the best.
FileSalvage is another option.
Jon
http://www.datasaversllc.com
PostPosted: October 4th, 2007, 23:32
You may try Stellar Phoenix MAC (Windows or MAC versioN).
It is slow, but very powerful product.
And also you may try R-studio V4.0 that supports HFS+.
regards
Pninja
PostPosted: October 5th, 2007, 3:53
In my humble opinion, Rstudio is good for imaging and raid reconstruction etc.. but for file retrieval it misses files or retrieves them bad. Not my preferable product.
Dobre
PostPosted: October 19th, 2023, 2:32
is there winhex template for APFS?
Users browsing this forum: No registered users and 55 guests
