 Post subject: Help with terminal of Samsung HM500JI
PostPosted: October 11th, 2012, 6:46
I have a Samsung HM500JI, it spins up, clicks loudly and then spins down.
Here is terminal:
*PA VID=0007 PN=0000 Rev=0004
PSL
U
S_0Shock Sensor Circuit Enabled
SO_1
Init RPM=0
IS=5
CLA #36/80
Handoff RPM=532
SPOK
mS1 00000003
A1O=2 A1G=426
O=509 S=2
***** VCM is stucked : status 1
SoUL!
Abnormal end
PK_3 C: 0 H:0
A1O=2 A1G=427
O=509 S=1
***** VCM is stucked : status 0
SoUL!
Abnormal end
PK_3 C: 0 H:1
A1O=2 A1G=428
O=509 S=1
SoUL!
Abnormal end
PK_3 C: 0 H:2
A1O=2 A1G=429
O=509 S=0
SoUL!
Abnormal end
PK_3 C: 0 H:3
A1O=2 A1G=429
O=509 S=2
SoUL!
Abnormal end
PK_3 C: 0 H:0
A1O=2 A1G=430
O=509 S=1
SoUL!
Abnormal end
PK_3 C: 0 H:1
A1O=2 A1G=431
O=509 S=0
SoUL!
Abnormal end
PK_3 C: 0 H:2
A1O=2 A1G=432
O=509 S=-2
SoUL!
Abnormal end
PK_3 C: 0 H:3
A1O=2 A1G=432
O=509 S=0
SoUL!
Abnormal end
PK_3 C: 0 H:0
A1O=2 A1G=432
O=509 S=2
SoUL!
Abnormal end
PK_3 C: 0 H:1
A1O=2 A1G=433
O=509 S=0
SoUL!
Abnormal end
PK_3 C: 0 H:2
A1O=2 A1G=433
O=509 S=2
SoUL!
Abnormal end
PK_3 C: 0 H:3
A1O=2 A1G=433
O=509 S=3
SoUL!
Abnormal end
PK_3 C: 0 H:0
A1O=2 A1G=434
O=509 S=1
SoUL!
Abnormal end
PK_3 C: 0 H:1
A1O=2 A1G=434
O=509 S=3
SoUL!
Abnormal end
PK_3 C: 0 H:2
A1O=2 A1G=434
O=509 S=3
SoUL!
Abnormal end
PK_3 C: 0 H:3
Unlatch Fail
Software unloading!
PK_4 C: 0 H:0
Software unloading!
PK_4 C: 0 H:0
LED 110B
LED 110B
At first I thought about bad heads, but that "VCM is stucked" makes me think it can be another problem...
Any hint?
Thanks!
Simone
 Post subject: Re: Help with terminal of Samsung HM500JI
PostPosted: November 18th, 2023, 6:38
Hello!
I had a case with same symptoms.
I changed upper and lower magnet, and the HSA.
The problem solved.
Your welcome!
PostPosted: November 18th, 2023, 16:47
It would appear that the VCM driver is unable to overcome the latch force. Other than replacing or checking mechanical components, one could increase the VCM current by adding a resistor in parallel with the current sense resistor (R220 near the motor controller?), but that would be risky. Perhaps you could measure the resistance of that resistor, or clean the VCM contacts at the HDA connector?
https://recuperodatos.com/sites/default/files/webform/donantes/02311-PCB.jpg
Users browsing this forum: No registered users and 47 guests
