Mikippp wrote:Hi,
Only the patient's ROM was successful
Mikippp
Thank you so much!!!
Everything worked out!
At first I was scared because of empty terminal after power up. Even got ready to return donor's ROM. But in last moment I pressed Ctrl-Z:
- Code:
Request spin / disc table recovery
ASCII Diag mode
F3 T>/O
F3 O>I
ALF Parametric Tables Preserved
Flash was erased and ALF Tables have successfully been initialized
Then I flashed the native ROM and ... it's aliiiiiiiiive
Amazing
Also, I didn't do any erase on donor, so theoretically it doesn't needed
Thank you for donor's patch also, maybe some day I'l get another donor PCB and make 1 TB SSHD with current donor's HDA
