 Post subject: Seagate ST8000DM004 Beep after head swap
PostPosted: May 1st, 2021, 7:11
Hello everyone,
i got a problem that i don't understand.
i perform a head swap on ST8000DM004,
it's a usual head swap like i always do and the donor drives is perfect too in fact the donor is brand new.
but after i replace the head, when power up its spinning then beeping, not like head stuck beep, its different, this sound it's more like alternating beeping sound.
to make sure the head is not stuck, i double-check it. Indeed, it is not stuck.
can anyone please help me, why it's beeping like that?
i never experience something like this after head swap on brand new head.
Thank you very much
File comment: DOnor
File comment: Patient
 Post subject: Re: Seagate ST8000DM004 Beep after head swap
PostPosted: May 2nd, 2021, 7:58
Could you upload a recording somewhere?
Without, it is difficult to say what you are experiencing.
PostPosted: May 2nd, 2021, 9:31
i think you beep tone like buzzer sound. Replace the PCB and check.
PostPosted: May 3rd, 2021, 3:36
I would check donor heads under microscope and or back in donor drive, will most likely reveal what you are dealing with.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: May 3rd, 2021, 5:18
yeah, a shorted pcb can cause pc3k power adapter beeping. Check with multimeter. If not shorted, attach the terminal log.
PostPosted: May 3rd, 2021, 9:35
Okay - I expected the "beeping" came from the harddrive :wink:
PostPosted: May 3rd, 2021, 12:19
we don't know that yet, it's just a possibility. A log would be helpful...
PostPosted: May 6th, 2021, 14:18
Is this a Helium-filled drive ?
PostPosted: May 6th, 2021, 14:51
does helium beep? :P
PostPosted: May 6th, 2021, 20:43
Why not?
Motor seizure or heads stucked to platters because of dropping or power failure?
PostPosted: May 7th, 2021, 7:17
i meant 'does HELIUM beep?' :)
anyway, OP said it is not stuck and it is spinning. So my bet is on either heads are 'incompatible' or just different enough to screw up the servo system.
A log - as always - would be helpful.
I haven't had this model yet, but by the shape of the cover i think it is not He filled, just a Perfectly Normal V11 Beast.
PostPosted: May 7th, 2021, 8:36
Yeah, it's not a He drive.
I've done a couple of them -- they're easier than expected :)
PostPosted: May 7th, 2021, 10:14
yeah, it is not a Beast, just Perfectly Normal, it's just for the phrase to be complete.
PostPosted: December 17th, 2023, 13:28
Hei, did you manage to get it to work?
Users browsing this forum: Google [Bot] and 236 guests
