 Post subject: samsung PCB bios swap?
PostPosted: October 18th, 2021, 7:31
Hello there,
I find myself in a bit of doubt lately, I'm acquiring a new SATA PCB BF41-00249B for this drive HM322IX (PCB BF41-00282A), Jared from DataMedics told me to use a sata PCB that is compatible but, I've no clue about how to swap the bios on this board.
But i can't find a guide or tutorial about this version of the PCB and i can't find a EEPROM 25xx or 24XX on the PCB.
Pictures of the drive attached
Slim Farza
Arobas Uldry Tunis
I.T. support and data recovery.
http://tunis.ausarl.ch
 Post subject: Re: samsung PCB bios swap?
PostPosted: October 18th, 2021, 10:26
There's no external rom on this one, so you may read and write it to the donor board through serport only.
PostPosted: October 18th, 2021, 12:26
What is wrong with the original PCB? Sometimes there is an easy fix (eg cold solder joint).
PostPosted: October 18th, 2021, 14:14
the drive has very unstable connection with the rapidspar and usb add-on. As you can read below the log of the drive, it does click rarely, and the usb-add on powers down the drive. Then the drive becomes unavailable.
Info    | 10/18/21 19:00:17 | Connected to RapidSpar DSR***** (ver. RS3.50a). RapidNebula license active until 7/1/2023
Warning | 10/18/21 19:00:17 | Source drive is not powered on. Please power on Source drive on RapidSpar unit or load existing project in target-only mode
Warning | 10/18/21 19:00:17 | Your Windows Defender real-time protection is turned on, which reduces recovery speed in some situations. To turn it off, launch DisableW10AntiSpyware.reg located in RapidSparAssistant directory.
Info    | 10/18/21 19:00:18 | Found USB Add-On 'DSU10455' (version 2.03a/203/200).
Info    | 10/18/21 19:00:41 | Running RapidNebula diagnostics and optimization ...
Warning | 10/18/21 19:00:51 | Nebula Diagnostics Failed
Info    | 10/18/21 19:00:51 | Source drive capacity is not reported. Can't run Media Test
Info    | 10/18/21 19:02:22 | Loading project ...
Error   | 10/18/21 19:04:31 | Failed to create project. Please run Nebula Diagnostics first and try again
Info    | 10/18/21 19:05:17 | Source: USB2.0 device
Info    | 10/18/21 19:05:17 | SCSI Product: 'Apollo UX'
Info    | 10/18/21 19:05:17 | SCSI Serial Number: '152D20329000'
Info    | 10/18/21 19:05:17 | Capacity: 298.1 GB (625142448 LBAs)
Info    | 10/18/21 19:06:04 | Source: USB2.0 device
Info    | 10/18/21 19:06:04 | SCSI Product: 'Apollo UX'
Info    | 10/18/21 19:06:04 | SCSI Serial Number: '152D20329000'
Info    | 10/18/21 19:06:04 | Capacity: ?
Info    | 10/18/21 19:06:43 | Source: USB2.0 device
Info    | 10/18/21 19:06:43 | SCSI Product: ''
Info    | 10/18/21 19:06:43 | SCSI Serial Number: '152D20329000'
Info    | 10/18/21 19:06:43 | Capacity: ?
Info    | 10/18/21 19:06:44 | Source: USB2.0 device
Info    | 10/18/21 19:06:44 | SCSI Product: 'Apollo UX'
Info    | 10/18/21 19:06:44 | SCSI Serial Number: '152D20329000'
Info    | 10/18/21 19:06:44 | Capacity: ?
Info    | 10/18/21 19:06:54 | Source: USB2.0 device
Info    | 10/18/21 19:06:54 | SCSI Product: ''
Info    | 10/18/21 19:06:54 | SCSI Serial Number: '152D20329000'
Info    | 10/18/21 19:06:54 | Capacity: ?
Info    | 10/18/21 19:07:00 | Source: USB2.0 device
Info    | 10/18/21 19:07:00 | SCSI Product: ''
Info    | 10/18/21 19:07:00 | SCSI Serial Number: '('
Info    | 10/18/21 19:07:00 | Capacity: ?
Info    | 10/18/21 19:07:16 | Source: USB2.0 device
Info    | 10/18/21 19:07:16 | SCSI Product: 'Apollo UX'
Info    | 10/18/21 19:07:16 | SCSI Serial Number: '('
Info    | 10/18/21 19:07:16 | Capacity: ?
Info    | 10/18/21 19:07:52 | Source: USB2.0 device
Info    | 10/18/21 19:07:52 | SCSI Product: 'Apollo UX'
Info    | 10/18/21 19:07:52 | SCSI Serial Number: '152D20329000'
Info    | 10/18/21 19:07:52 | Capacity: ?
Slim Farza
Arobas Uldry Tunis
PostPosted: October 18th, 2021, 14:29
Sorry but i'm unfamiliar about serport. Could you explain it to me please?
Slim Farza
Arobas Uldry Tunis
PostPosted: October 18th, 2021, 15:12
Serial port / UART / terminal.
PostPosted: October 18th, 2021, 16:59
oh i've got an USB device to that but never used...
Slim Farza
Arobas Uldry Tunis
PostPosted: October 18th, 2021, 17:52
In fact, it is possible to program the target board through SATA as well, once it comes readz, but you need to read it first. ...and will also need a flash loader, if you have no tools that support writing rom on this family.
PostPosted: February 1st, 2024, 5:00
Can anyone tell me how to solder the SATA port to this exact PCB???
I have same issue. It is very slow and having IO issues through USB. I want to convert that USB to SATA so i can plug it in PC3000 and run it from there
PostPosted: February 1st, 2024, 12:52
In general, locate the SATA Tx/Rx differential pairs that run between the bridge and MCU. There will be 4 capacitors somewhere along these traces. Remove these capacitors and solder your SATA wires at the MCU end of each capacitor. Use the equivalent SATA PCB to identify the order of these wires by following the path from MCU to SATA connector.
PostPosted: February 1st, 2024, 15:14
JM20329
21 - RXP(+)
22 - RXN(-)
25 - TXN(-)
26 - TXP(+)
Capacitors next to the chip JM2039.
They are usually unsoldered and placed (soldered) vertically on contact from the CPU.
SATA lines are soldered to the top contact.
PostPosted: February 1st, 2024, 15:47
Use this photo as a guide for the SATA Tx/Rx pairs.
https://recuperodatos.com/sites/default/files/webform/donantes/02311-PCB.jpg
Converting a USB HDD PCB to SATA:
https://www.hddoracle.com/viewtopic.php?p=22476#p22476
Users browsing this forum: No registered users and 35 guests
