March 2nd, 2024, 9:33
Would anyone have a hitachi DK23FA-40 microcode file to share?
Thanks.
March 5th, 2024, 13:01
This would be the disk model, if someone has it and can extract the firmware resources (mainly microcode), I would reward by paypal.
- Attachments
March 6th, 2024, 3:11
I've got some similar, but not this exact one.
March 6th, 2024, 18:39
Thanks Dimitri. I also have the same model (family) in 30GB and 60GB but in native Hitachi for it to be compatible the microcode has to be of the same family and capacity (as far as I know). Or repair it, but I have no idea if this is possible.
Anyway thank you very much for bothering to check if you had it.
March 6th, 2024, 18:58
I have one resource for this model, but the microcode folder is empty ...
When you say "repair it", are you referring to the microcode or the PCB?
March 6th, 2024, 20:46
Hi Frank, thanks also for taking the trouble to look.
I would need to repair/replace the microcode which is damaged, the pcb is fine. The microcode in Hitachi Native is the "Grandfather/Father" of the NV-RAM in Hitchi-IBM. NV-RAM there are methods to repair it but I don't know for this "family member".
I also found something but also without the microcode, the reason is that dumping it takes about 20/30Mtos.
I'll keep looking....... They are very old units and it is difficult for someone to have it in a database. The most feasible is that someone who has that model and bothers to do the dump (would be rewarded).
Many thanks, Frank
March 6th, 2024, 21:02
Can you upload some examples? Maybe we could identify those parameters which apply to the model and those which apply to each drive. It would be an interesting exercise for me in any case.
March 7th, 2024, 12:42
I have started to analyse the NVRAM for the HTS421280H9AT0 model. I think I might be able to repair your NVRAM if the corruption is not too severe.
For a start, there is a 16-bit XOR checksum which is computed over the range from 0 to 0x1CF. It should be 0x0000.
March 7th, 2024, 15:54
I notice that this model has two completely different PCBs.
https://dsmcz.com/prestashop/16356/chip-2p00f6m4b62394za21005-hts428040f9at00-40gb-25-ide.jpg (older version)
https://cdn11.bigcommerce.com/s-6bkt1ygjlf/images/stencil/1280x1280/products/552061/633675/PCB-HTS428040F9AT00-lg__44021.1635488182.jpg (newer version)
Does this make a difference?
(I also notice that most suppliers incorrectly identify the major ICs on the older PCB.)
Edit:
The newer PCB is a Seagate. It seems that the suppliers may have this wrong, too?
March 7th, 2024, 16:49
Thanks for your trouble on this matter Frank.
I will attach shortly two microcode files, the original (corrupted) and one of a model I have operational of the same family but 60GB. I have checked them and except for the module structure, the data is nothing alike.........
I haven't seen the seagate PCB on this model, the one on the disk we are talking about would be the first.
March 7th, 2024, 21:22
Hi Frank,
Please find attached two microcodes from the HITACHI DKFA family, the one corresponding to the patient (Bad) and another one from a 30GB disk of the same family.
- Attachments
- HITACHI_DK23FA.rar
- (489.18 KiB) Downloaded 475 times
March 8th, 2024, 1:45
Microcode.bin is comprised of 0x200-byte sectors, each with the following structure:
- Code:
offset description
0x000 always 0x3A
0x001 - 0x002 sector number (big-endian)
0x003 always 0x00
0x004 - 0x103 0x100 data block
0x104 - 0x107 32-bit sum of preceding bytes (big-endian)
0x108 - 0x1FF all 0xFF
This is the second sector (0x033E):
- Code:
00000200 3A 03 3E 00 43 18 78 00 31 01 60 11 47 70 00 00 <--- sector 0x033E
00000210 00 80 0E 00 01 FF 09 8C 00 80 0F 00 00 C0 08 00
00000220 0A 41 02 49 4A 04 68 93 42 99 D0 00 60 91 05 C0
00000230 4B 02 0D C0 43 18 47 70 00 80 0F 00 00 C0 08 00
00000240 B5 80 4F 0A 7D 38 08 80 D2 0D 48 09 49 09 60 01
00000250 20 00 60 78 48 08 F7 FF FE 81 28 31 D1 03 7D 38
00000260 23 02 43 18 75 38 BC 80 BC 08 47 18 01 FF 09 8C
00000270 01 FF 09 B0 EA 00 CC BE 01 FF 09 90 47 00 47 08
00000280 47 10 47 18 47 20 47 28 47 30 47 38 43 50 4D 20
00000290 52 65 76 20 5A 38 42 30 30 31 30 30 00 00 00 00
000002A0 E5 9F C0 00 E1 2F FF 1C 01 FF 00 01 00 00 00 00
000002B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000002C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000002D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
000002E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
000002F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00000300 FF FF FF 13 00 00 64 93 FF FF FF FF FF FF FF FF <--- checksum = 0x00006493
00000310 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00000320 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00000330 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00000340 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00000350 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00000360 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00000370 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00000380 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00000390 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
000003A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
000003B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
000003C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
000003D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
000003E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
000003F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
The sector count starts at max sector and decrements to 0 at the final sector.
There is a 32-bit checksum at the end of each 0x100-byte block of data. This checksum is computed by adding the preceding 0x104 bytes (0x100-byte data + 4-byte header).
It should be possible to verify the integrity of microcode.bin by validating the checksum of each sector and confirming that the padding is 0xFF. I'll write a simple tool to do this.
March 8th, 2024, 1:57
I don't understand where microcode.bin is located on the drive.
If this is the PCB ...
https://dsmcz.com/prestashop/16356/chip-2p00f6m4b62394za21005-hts428040f9at00-40gb-25-ide.jpg... then the controller (IC5) has only 256KB of flash memory. This can accommodate original.bin (208KB) but not microcode.bin (416KB).
S3F443FX, Samsung, 16/32-Bit RISC Microcontroller, 1.8V core, 3.3V I/O, 256KB Flash (64K x 32-bit) , 8KB SRAM (2K x 32-bit) , 64-LQFP:
https://pdf1.alldatasheet.com/datasheet-pdf/download/111459/SAMSUNG/S3F443FX.htmlEdit:
I notice that a file of the same size and structure as original.bin can be created by stripping out the 0x100-byte data blocks from microcode.bin in reverse order. I'll do this, too.
March 8th, 2024, 2:23
AFAICT, original.bin is a raw dump of the 256KB embedded flash. I'm wondering whether microcode.bin is a loader created by PC3K from the raw flash dump, in which case there would be no point in examining it.
March 8th, 2024, 6:06
fzabkar wrote:AFAICT, original.bin is a raw dump of the 256KB embedded flash. I'm wondering whether microcode.bin is a loader created by PC3K from the raw flash dump, in which case there would be no point in examining it.
That is correct, Frank
"Upon completion of the reading procedure the utility generates two files: «Original.bin» and «Microcode.bin». The first file contains a binary ROM image. The second is used to store compiled microcode required for the «Write HDD microcode» command".
March 8th, 2024, 12:29
I found a Lenovo firmware update, version A75A for HTS4240xxM9AT00. It updates several SA modules, but not the ROM. :-(
Perhaps you could look for other firmware updates?
BTW, I thought you wanted to check the NVRAM?
March 9th, 2024, 16:47
Is 50 EUR too much for a complete drive? It appears to be a different firmware version, though.
https://drive-for-parts.com/HTS428040F9AT00-PN-HTS428040F9AT00-HITACHI-IDE-HARD-DRIVE-D1122
