 Post subject: WinBond 25Q17DWS14, What is the Size of the ROM?
PostPosted: February 17th, 2022, 6:13
It's First Time I have Got a ROM with ODD Number on It.
Has Anyone Got Clue Here . I Need to Unlock it Actually .
ST2000DM005-2CW102
 Post subject: Re: WinBond 25Q17DWS14, What is the Size of the ROM?
PostPosted: February 17th, 2022, 6:43
https://supply24.online/doc/manual/Polu ... 171023.pdf
PostPosted: February 17th, 2022, 12:45
Warning: the Winbond part is a 1.8V device.
PostPosted: February 17th, 2022, 13:56
I could not find the datasheet on Winbond site.
If the PCB is working, try powering it up to measure Vcc and IOs pins to be sure on the voltage. I suppose it is 1,8V.
Next try a cheap CH341A adapter to read it.
**NOTE** standard CH341A uses 5V on its Vcc pin. You can modify it to provide 3,3V (pin 9 => to 3,3V and cut track & Vcc pin => to 3,3V). Now you have a 3,3V device. You can them buy a 1,8V converter for it and try to scan it using several free eeprom readers software. You can them use the flash id sequence to retrieve information about it.
PostPosted: February 18th, 2022, 8:41
This works at 1,8V
https://it.aliexpress.com/item/40011201 ... pt=glo2ita
This software should work fine with it
https://khandishnetwork.com/dl/neoprogr ... 2-06-2021/
My firmware database:
PostPosted: February 18th, 2022, 14:06
This is Winbond's part numbering system (different IC):
PostPosted: February 24th, 2022, 12:52
Have you been able to read this chip? I bought new HDDs and this time I'll make ROM backups as well - and two of them uses this chip and I was unable to read them (HDDs are working..)
If so, could you provide me more info on how to do it and the tools you used?
Best regards!
Eduardo
PostPosted: March 29th, 2024, 6:01
You can read with this: W25Q16DW
Ivan Jurić
DataSector - Data Recovery Services Croatia
http://www.datasector.hr
PostPosted: March 29th, 2024, 6:12
I was able to read it by setting chip size manually, and unchecking "check ID" while reading .
Users browsing this forum: No registered users and 204 guests
