 Post subject: Seagate ST1000LM035 DSC FAIL after head change. Error in ROM
PostPosted: May 10th, 2024, 3:55
I have this Seagate ST1000LM035-1RK72 WQ9283K7 FW:0001 which is weak and died upon recovery.
Changed new sets of heads > was clicking for a while > got DSC FAIL error > Performadoubledownloadwithoutapowercycle > goes into DRD state > but cannot do anything
Upon unlocking Tech mode i noticed this errors.
What can i do in this situation??
Anyone can help?
Thanks!
File comment: ROM Unlocking ERROR
436592361_3706898886305250_604240151697957729_n.jpg [ 119.97 KiB | Viewed 1733 times ]
File comment: Error after changing heads
 Post subject: Re: Seagate ST1000LM035 DSC FAIL after head change. Error in
PostPosted: May 10th, 2024, 4:49
The "used space" and "whole space" checksum errors are bogus. Segment 2B contains SMART attribute data.
PostPosted: May 10th, 2024, 6:05
check if pcb is native
PostPosted: May 12th, 2024, 22:57
yes. its native
PostPosted: May 12th, 2024, 23:01
By bogus: you mean they are fake?? Fake logs?
PostPosted: May 13th, 2024, 0:12
No, the data is OK, but there are no checksums. PC3000 is wrong.
PostPosted: May 13th, 2024, 2:58
Ok that means. The heads must be incompatible
PostPosted: May 13th, 2024, 9:02
No.
It means PC3k gives false negatives.
PostPosted: May 13th, 2024, 15:32
Use F3RomExplorer to extracts those segments to a file, then analyse the files with a hex editor.
https://www.hddoracle.com/viewtopic.php?p=18531#p18531
PostPosted: May 16th, 2024, 0:12
northwind wrote:
No.
Yeah i mean if it is false negatives. Then what could the problem be??
PostPosted: May 16th, 2024, 2:07
Do the new heads still work in the donor drive?
PostPosted: May 16th, 2024, 4:58
the error means drive can read servo fine but cannot sync on sector, on both sa copies, which suggests it is looking at wrong location, which typically happens if rom is not native or head map is screwed.
Or both heads are weak, but i consider that having less chance.
PostPosted: May 16th, 2024, 5:00
Yes. They work flawlessly!
PostPosted: May 16th, 2024, 10:03
I would say this is a typical issue of scratches to the surface that preventing heads from loading SA.
