Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: ROM For Seagate ST2000DM008 NEEDED
PostPosted: May 24th, 2024, 8:13
After writing the ROM i get the following error in terminal
Flash boot code Digital Signature Verification failure!
0x00000001
0x00000001
0x00000001
0x00000001
0x00000001
0x00000001
0x00000001
0x00000001
0x00000001
0x00000001
SEA5 Boot ROM 1.0 (06/01/2017)
Copyright Seagate 2017-VM000
and the drive doesnt spin.
Some more ideas please?
PostPosted: May 24th, 2024, 13:12
Did you write both patched ROMs to the correct donor PCB?
PostPosted: May 24th, 2024, 13:54
This PCB supplier states that a ROM swap should work for ...
    Model : ST2000DM008
    Board Number: 100815595
    P/N : 2FR102-020
    F/W : 0001
https://www.hdd-parts.com/21112805.html
Assuming they are correct, this would suggest that the early version of this PCB may not have a keyed MCU. Perhaps one could transfer the patient ROM to this early PCB?
HDD Surgery shows two families for the ST2000DM008-2FR102, both with F/W 0001:
https://firmware.hddsurgery.com/index.php?manufacturer=Seagate&family=Pharaoh_Oasis
https://firmware.hddsurgery.com/index.php?manufacturer=Seagate&family=V9
I wonder if one family is without a digital signature? It would be interesting to compare a V9 ROM dump against a Pharaoh_Oasis.
PostPosted: May 24th, 2024, 14:45
See this thread:
https://forum.hddguru.com/viewtopic.php?f=1&t=43332
ISTR that someone said that this PCB came with a keyed MCU and a non-keyed MCU, and it is impossible to distinguish between them visually.
PostPosted: May 25th, 2024, 1:20
I think the problem is "write ROMs to the correct donor PCB"...
PostPosted: May 25th, 2024, 1:30
See this thread:
That post case of "jamesrajesh007" was solved with Donor PCB.
For your case, can u post Patient PCB ROM and Donor PCB ROM?
PostPosted: May 25th, 2024, 15:04
I think so, too.
gps31 wrote:
See this thread:
The OP already posted both. Where do you think the patched ROMs came from?
As for that other post, was the donor MCU "locked", or was the PCB an earlier unlocked one? It would have been nice if you had updated that other thread with your solution.
PostPosted: May 26th, 2024, 4:36
i will search donor PCB with below ROM code match
and transfer if digital signature is in Patient ROM to Donor ROM as well as SAP RAP CAP
then it will surely work.
here donor and patient PCB ROM are not match
Note; fzabkar sir if u PM your email i will send how that 4TB case solved with Patient rom, donor rom and modified rom
