 Post subject: Re: ST2000DM001 BSY
PostPosted: November 2nd, 2016, 11:32
Bad-sectors in MediaCache, and probably in some other modules as well. You can try to catch drive by shortening the read channel.
PostPosted: February 22nd, 2017, 19:57
I have the same problem
PostPosted: February 22nd, 2017, 20:36
If the data on it is valuable to you, DO NOT open the lid, DO NOT play with it DO NOT send commands to it
As a matter of fact do nothing except than sending it to a DR pro I repeat a DATA RECOVERY PROFESSIONAL ONLY (not to a computer repair shop/computer tech).
PostPosted: February 23rd, 2017, 4:52
I don't have any important information on it,I buy this hdd because I want to unlock it and sell,I have ttl adapter and when I connect this hdd on it and start terminal hdd send me this message.And when I run script hdd send me "COMMUNICATION PROBLEM.SCRIPT STOP
LED:00000047 FAddr:060BE178
Rst 0x10M
Rst 0x10M "
PostPosted: February 23rd, 2017, 18:33
It is a Seagate, DM Series, and has already presented problems.
Just dump it, or sell as defective/for parts. Any "cosmetic" thing done to it would be just a scam.
PostPosted: February 25th, 2017, 7:14
Where I have to jump on this board?
This is seagate momentus 7200 fde.2 :(
 Post subject: Seagate vvvvvvvvvv in terminal
PostPosted: June 4th, 2024, 12:09
The issue affecting one Seagate hard disk that shows vvvvvvvvvv in terminal is pretty common, at least at our labs
The drive goes DRD DSC at first sight, but then if you try to read ID, also the BSY LED turns on
while the terminal outputs many rows of strings and vvvvvvvvvv
if you need support with this type of problem , feel free to contact me
for techs guys, you don't need any short of reading channels
Users browsing this forum: No registered users and 68 guests
