 Post subject: Seagate st1000DM003 FW:CC4B. Bios does not recognize. Help!
PostPosted: December 6th, 2015, 3:10
Hi!
I have Seagate st1000DM003 PN:9YN162-500 FW:CC4B and it stop working. I managed to pull this out from terminal....
Up
TCC-0019[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-0019
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 01747170
[RSRS] 019B
Reconstruction: Completed 1:
[MCMTWS]
: MCTStateFlags 0000002A MCStateFlags 00000041
MCMainPOR: Feature Enabled...
[SR] 0002
RAW ON After Spinup for counter=0x00002000, BlkAddr=0x000000000015C04B
[000000000015C04B]vvvvvvvvvv
Starting LBA of RW Request=000000000015C04B Length=00000001
ProcessRWError -Write- at LBA 000000000015C04B Sense Code=C3160081[000000000E9
99362]vvvvvvvvvv[000000000E999363]vvvvvvvvvv[000000000E999364]vvvvvvvvvv[0000000
00E999365]vvvvvvvvvv[000000000E999366]vvvvvvvvvv[000000000E999367]vvvvvvvvvv[000
000000E999368]vvvvvvvvvv[000000000E999369]vvvvvvvvvv[000000000E99936A]vvvvvvvvvv
[000000000E99936B]vvvvvvvvvv[000000000E99936C]vvvvvvvvvv[000000000E99936D]vvvvvv
vvvv[000000000E99936E]vvvvvvvvvv[000000000E99936F]vvvvvvvvvv[000000000E999370]vv
vvvvvvvv[000000000E999371]vvvvvvvvvv[000000000E999372]vvvvvvvvvv[000000000E99937
3]vvvvvvvvvv[000000000E999374]vvvvvvvvvv[000000000E999375]vvvvvvvvvv[000000000E9
99376]vvvvvvvvvv[000000000E999377]vvvvvvvvvv[000000000E999378]vvvvvvvvvv[0000000
00E999379]vvvvvvvvvv[000000000E99937A]vvvvvvvvvv[000000000E99937B]vvvvvvvvvv[000
000000E99937C]vvvvvvvvvv[000000000E99937D]vvvvvvvvvv[000000000E99937E]vvvvvvvvvv
[000000000E99937F]vvvvvvvvvv[000000000E999380]vvvvvvvvvv[000000000E999381]vvvvvv
vvvv[000000000E999382]vvvvvvvvvv[000000000E999383]vvvvvvvvvv[000000000E999384]vv
vvvvvvvv[000000000E999385]vvvvvvvvvv[000000000E999386]vvvvvvvvvv[000000000E99938
7]vvvvvvvvvv[000000000E999388]vvvvvvvvvv[000000000E999389]vvvvvvvvvv[000000000E9
9938A]vvvvvvvvvv[000000000E99938B]vvvvvvvvvv[000000000E99938C]vvvvvvvvvv[0000000
00E99938D]vvvvvvvvvv[000000000E99938E]vvvvvvvvvv[000000000E99938F]vvvvvvvvvv[000
000000E999390]vvvvvvvvvv[000000000E999391]vvvvvvvvvv[000000000E999392]vvvvvvvvvv
[000000000E999393]vvvvvvvvvv[000000000E999394]vvvvvvvvvv[000000000E999395]vvvvvv
vvvv[000000000E999396]vvvvvvvvvv[000000000E999397]vvvvvvvvvv[000000000E999398]vv
vvvvvvvv[000000000E999399]vvvvvvvvvv[000000000E99939A]vvvvvvvvvv[000000000E99939
B]vvvvvvvvvv[000000000E99939C]vvvvvvvvvv[000000000E99939D]vvvvvvvvvv[000000000E9
9939E]vvvvvvvvv[000000000E99939F]vvvvvvv[000000000E9993A0]vvvvvvvvvv[000000000E9
993A1]vvvvvvvvvv[000000000E9993A2]vvvvvvvvvv[000000000E9993A3]vvvvvvvvvv[0000000
00E9993A4]vvvvvvvvvv[000000000E9993A5]vvvvvvvvvv[000000000E9993A6]vvvvvvvvvv[000
000000E9993A7]vvvvvvvvvv[000000000E9993A8]vvvvvvvvvv
Whether anyone come against the corresponding?
It will do this forever. Ideas for what I should do next?
Thank you in advance.
 Post subject: Re: Seagate st1000DM003 FW:CC4B. Bios does not recognize. He
PostPosted: December 6th, 2015, 14:47
It looks like it's busy trying to reassign bad blocks. If you wait until it finishes the process and turn off reallocation with the right terminal commands, you'll probably be able to image the drive.
Data Recovery Cape Town
PostPosted: December 8th, 2015, 20:29
Seagate DM P/N: 9YNxxx
I not expect anything good in this series.
I would say bad heads/media
 Post subject: Seagate Grenada BSY with vvvvvvvvvv in terminal
PostPosted: June 4th, 2024, 12:12
The issue affecting one Seagate hard disk that shows vvvvvvvvvv in terminal is pretty common, at least at our labs
at first sight it goes DRD DSC but as soon you try to read ID, also BSY turns on while the terminal outputs many rows of strings and vvvvvvvvvv
if you need support with this type of problem , feel free to contact me
for techs guys, you don't need any short of reading channels
Users browsing this forum: No registered users and 68 guests
