 Post subject: IBM Firmware Required for HUC101812CSS20
PostPosted: March 25th, 2023, 16:19
Hi Gurus,
I Have Several 1.2TB 10k SAS Disks (HUC101812CSS20).
I need IBM firmware to make them work in IBM V3700 and V7000 Storage systems.
If anyone can share the firmware it would be great.
 Post subject: Re: IBM Firmware Required for HUC101812CSS20
PostPosted: April 9th, 2023, 14:59
there isn't a firmware for those drives to make them work with ibm server. normally it's a plug n play. Worse case scenario go update the bios of your server.
Slim Farza
Arobas Uldry Tunis
I.T. support and data recovery.
http://tunis.ausarl.ch
PostPosted: April 13th, 2023, 10:30
Your statement couldn't be further away from the truth. :-)
The firmware i am looking for is a storage firmware not a server firmware. Servers normally don't require specific firmware. Storage on the other hand is a different game altogether. Every OEM vendor locks disks at the firmware level so that only their specific firmware disk works in their storage.
The Same Manufacturer (HGST/Seagate) Disk works in different OEM (Dell/HP/IBM) Storage with the specific firmware from that OEM.
You can actually install the OEM firmware on standard disks to make them work in OEM Storage systems. I have had this done previously for different storage systems.
PostPosted: June 6th, 2023, 18:51
Are you still interested? Do you really need IBM or Lenovo?
PostPosted: July 19th, 2023, 22:39
I would be interested in converting Seagate Exos X18 drive (3CD233, ST10000NM015G) to a drive compatible with IBM Flashsystem 5035 (IBM P/N 03JK890). Is there any way to accomplish that?
PostPosted: June 26th, 2024, 5:04
Yes. I am still interested.
Do you know how to do this?
