 Post subject: Help to identify burnt IC on HP Motherboard L75365-001
PostPosted: August 8th, 2024, 3:11
I know it's not directly related to HDD but if somone can help me identify this burnt IC on my motherboard. I've posted on other forum but no answer.
I've search here http://markingcodes.com/search/c/ld but the marking is odd, I can't find anything. I beleive it's a Mosfet QFN 20. ID burned after a stor/ligntening. Now PC start for one seconds and stop.
Sam
WhatsApp Image 2024-08-02 à 13.33.02_f34644a6 (1).jpg [ 427.2 KiB | Viewed 4934 times ]
 Post subject: Re: Help to identify burnt IC on HP Motherboard L75365-001
PostPosted: August 8th, 2024, 3:21
https://www.ti.com/packaging/en/docs/partlookup.tsp?partmarking=127
Probably "1275C", in which case a TPS51275C.
https://www.ti.com/lit/gpn/tps51275c
Also ...
http://markingcodes.com/search/c/1275c
http://markingcodes.com/search/c/127 (third page)
Why were you searching for "LD"????
PostPosted: August 8th, 2024, 3:53
thank you very much !
PostPosted: August 8th, 2024, 17:51
I would check the MOSFETs as well.
https://qinwei.haoduomoban.com/uploads/20240713/c64ac59a78b8960c746852126f610337.pdf (QN3102M6N)
https://datasheet.sisoog.com/file/7a657573/datasheet/0b6d71c35b68d1e65d0f6807a81f04c16f9f7983.pdf (QN3106M6N)
Users browsing this forum: No registered users and 81 guests
