Doubt hdd case aluminum
August 17th, 2024, 20:20
Using a 2.5" USB 3.0 aluminum case on my notebook HDD can cause problems with static and short circuit if the HDD logic board underneath touches the aluminum of the case?
Re: Doubt hdd case aluminum
August 17th, 2024, 21:20
Aluminum is conductive, it can short out a PCB. However, these products usually come with a clear plastic sticker you affix to the PCB, or there are rails which the insert rides on which prevents contact.
August 18th, 2024, 6:05
photo of my case
August 18th, 2024, 6:07
other photo
https://ae01.alicdn.com/kf/S0910b24dceb ... .jpg_.webp
August 18th, 2024, 13:46
You are posting useless commercial pictures instead of personal ones.
These pictures doesn't allow judging the protection level against shorts on the PCB.
By the way, sonicmario, are you prepared for an EMP?
August 18th, 2024, 13:54
I bought this case but I haven't received it yet, so the photos are from the internet. I need to discard this case due to the risk of static and short circuit in hdd?
August 19th, 2024, 21:19
sonicmario wrote:I bought this case but I haven't received it yet, so the photos are from the internet. I need to discard this case due to the risk of static and short circuit in hdd?
I give up. You're impossible to talk too. rec told you we can't answer your question properly unless we see a real life picture and I told you these products usually come with a clear plastic sticker or the rails on the insert prevents contact.
