 Post subject: How to change interface speed
PostPosted: September 24th, 2024, 17:21
Hi all, I'm new here! :D :D :D
I have a Seagate ST1000VM002 and i checked with seatools and crystalDisk that the Interface used is SATA 150 and the supported is sata 600. Is there a way to change this?
 Post subject: Re: How to change interface speed
PostPosted: September 24th, 2024, 21:11
Why?
https://www.seagate.com/files/staticfiles/support/docs/manual/ce/Pipeline%20HD%20Series/100633414f.pdf
Sustained data transfer rate OD ---- 159MB/s
PostPosted: September 25th, 2024, 14:33
high instantaneous (burst) data-transfer rates with a default of 6Gb/s for ST1000VM002 and ST2000VM003
models. Limit settings for 1.5Gb/s and 3.0Gb/s are available via S.M.A.R.T. Command Transport command.
Reading the same manual that you provided, I read this and I Thought that It is limited via S.M.A.R.T
anyway if there is no possibility in changing that feature it doesn't matter that much, is a common hdd that I try to squeeze all it's potential.
Users browsing this forum: No registered users and 83 guests
