 Post subject: Toshiba disable head
PostPosted: October 1st, 2024, 9:33
I disabled toshiba head 0 then power off\on there was a very slight noise but drive id with head 01 active and head 0 successfuly disabled and can read head 01 lba smoothly.
Then I cut this head 0 physicaly power off\on but now drive clicking hysterically,after a while drive id but no access to head 01 lba (could not load p list).
I took another hard disk of the same model and disable head 0 but now I only pushed the head 0 a little so it wouldn't touch the platter 0 surface power off\on and again drive clicking hysterically,after a while drive id but no access to head 01 lba.
Does anyone know an explanation for this?
 Post subject: Re: Toshiba disable head
PostPosted: October 2nd, 2024, 4:51
what do you mean by disabling head 0?
PostPosted: October 5th, 2024, 17:00
What you did explain the Clicking sound
PostPosted: October 7th, 2024, 10:53
Write back the original (ROM) If you did not backup the Rom you are out of luck.
Data Recovery, Remote support & Training https://disksolution.com.pk/
