 Post subject: Toshiba N300 HDWG21C - Simple BIOS chip transfer possible?
PostPosted: December 12th, 2024, 17:46
Anyone know if it is/isn't possible to just transfer the chip on these?
 Post subject: Re: Toshiba N300 HDWG21C - Simple BIOS chip transfer possibl
PostPosted: December 12th, 2024, 21:26
Is this a qualified diagnosis such as you know the pcb has an issue or are you trying to apply the common internet myth that swapping a pcb will solve all problems?
Zero Alpha: zeroalpha.com.au
PostPosted: December 12th, 2024, 21:41
Does this PCB have 4 "ROMs"?
PostPosted: December 13th, 2024, 9:31
I have someone asking about repair (not recovery) on 2 of these with the connectors and all pads lifted, so swapping to an intact board is obviously preferable to patching them up.
PostPosted: December 13th, 2024, 9:39
I'll ask them to confirm ICs 5-7, but looks like it probably does.
PostPosted: December 13th, 2024, 15:39
IMO it would be easier and safer to hardwire the power and data lines. But that begs the question, was the drive subjected to physical trauma, and is there a likelihood of internal damage?
PostPosted: December 17th, 2024, 2:57
Hi ,
i dont remember but it as only one chip out of the several that i swapped and the donor board worked ,But you can also swap al of them whats the big deal do it one by 1
Users browsing this forum: No registered users and 40 guests
