Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: western digital PCB repair SATA FUSE .. help me to clari
PostPosted: January 16th, 2025, 9:31
sorry i forget to write LONG BEEP on the broken PCB
PostPosted: January 16th, 2025, 17:28
https://www.hddoracle.com/viewtopic.php?p=22339#p22339
PostPosted: January 16th, 2025, 21:14
thank you for your time Sir i really apreciate it
i alreare replaced the e-fuse... but same no 12v....
PostPosted: January 16th, 2025, 21:53
If 5V and 12V at present at the input, but one or the other is not present at the output, then the chip is faulty or the corresponding supply is shorted to ground.
PostPosted: January 16th, 2025, 22:03
thank you for your time responding Sir.i cant thank you enough
iv swapped the e-fuse from healthy donor board! the e-fuse of broken board work fine on donor board Sir may the smooth chip?
PostPosted: January 17th, 2025, 7:47
which chip you mean Sir?
