 Post subject: Control hdd heads position while reading lba
PostPosted: February 2nd, 2025, 20:16
There is a behavior pattern when hdd head reading user sectors,they occasionally move from the reading area to a fixed area in the center of the platter and then return and continue reading(in sector by sector reading mode not reading fragmented files situation).
Does anyone know what part of the firmware controls this?
Is this s.m.a.r.t?
 Post subject: Re: Control hdd heads position while reading lba
PostPosted: February 2nd, 2025, 20:51
Are you talking about the parking zone on old drives before ramps were in use?
Zero Alpha: zeroalpha.com.au
Find Cheap Donor Drives App: https://www.zeroalpha.com.au/donor-drive-app Updated January 2025
PostPosted: February 2nd, 2025, 21:16
No,modern hdds with ramp, the heads stop reading and move to the middle of the platter for a split second and then go back and continue reading from the original area.
PostPosted: February 4th, 2025, 3:00
If this happens at a few sectors repeatably, then probably some servo sector(s) are damaged around the affected LBAs.
It can be head, preamp or PCB related as well, but less likely, and in this case it would happen independent of the LBAs being accessed.
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot] and 87 guests
