April 3rd, 2025, 23:25
I got HTS545032B9A300 2.5" SATA HDD Hitachi, spin down. It spin in the first time and spindle down.
I can't access to SA. Anyway to short pins? Any short pins information?
Or it may other way.
Thank you.
- Attachments
- IMG20250404102151.jpg (57.85 KiB) Viewed 11153 times
- IMG20250404102137.jpg (60.85 KiB) Viewed 11153 times
April 3rd, 2025, 23:28
Sorry, wrong model, it is HTS543225L9A300
April 4th, 2025, 4:14
KangKung wrote:I can't access to SA. Anyway to short pins? Any short pins information?
Yep, you can try to short VCC and GND test pins, it really may help. Enjoy!
April 4th, 2025, 4:21
It's opened.
Did you change heads?
April 4th, 2025, 5:27
Hi Northwind,
Yes, head replaced with same donor.
Currently no more spin down, it is READY, but having error when access to SA.
No ID detection yet.
- Attachments
April 4th, 2025, 5:53
KangKung wrote:It spin in the first time and spindle down.
As you wrote above, I thought the spindle motor does not spinning. So does it rotating or not?
If heads are changed, spindle motor continues to spinning, and no clicking sound, then I would check the NV-RAM version first. It may be an alien PCB & ROM. Check the NV-RAM version in the ROM and version at the HDA label.
April 4th, 2025, 6:33
Hi aekhv,
Spindle is spinning and keep spinning after head replacement.
Head is moving, I heard one click, no clicking.
When selecting ID, drive READY with ERROR and ABR.
Let me check the NV-RAM version in the ROM... compare to the label.
Who knows wrong PCB.
Thank you.
April 4th, 2025, 6:37
According to shield warranty stickers on HDD and PCB, it is originally unopened.
Anyway I will check ROM.
April 4th, 2025, 6:38
This is Hitachi IBM, not ARM
April 4th, 2025, 6:48
gold6565 wrote:This is Hitachi IBM, not ARM
Actually yes, you're absolutely right.
