Samsung ST1000LM024 Can't Read ROM
June 16th, 2025, 13:35
Using latest version of PC-3000 Express.
Patient Drive is a Samsung ST1000LM024
The drive spins up and sounds good, drive does not ID and no PHY. I suspect PCB Issue. I took PCB from similar drive (same model number, but not exact firmware version) and connected to the drive just to see if I get PHY, which it does.
I have ordered an exact match donor and intend to copy the ROM from the patient PCB to the donor PCB.
I am trying to read the ROM from the patient drive using terminal, but I am getting the following message:
Read ROM via terminal
Error pulse set error; Terminal is busy (6)
Test interrupted
Any suggestions?
Re: Samsung ST1000LM024 Can't Read ROM
June 16th, 2025, 19:33
Just read it out with a programmer.
What do you see when you power up the drive in terminal with native PCB?
June 17th, 2025, 10:05
WebClaw wrote:Just read it out with a programmer.
Hi. Thank you for your response. The drive spins up (sounds normal), the drive does not ID. Nothing shows in the terminal window. If I try to read the ROM, the red light on the terminal adapter flashes a few times then the log says: Terminal is busy (6) and then asks to switch the drive to test mode. If I click yes, the drive get powered on/off multiple times and displays multiple "terminal is busy" errors.
I am trying to read through PC-3000 without a programmer as I would prefer NOT to desolder if possible. If I have no other choice, I'll manually transfer the ROM chip from the Patient PCB to the Donor PCB. I'd prefer not to do that if possible.
June 17th, 2025, 11:21
Not possible for this drive to show nothing in term. It will show preamp data before the drive spins. Check your connector.
June 17th, 2025, 20:32
Any chance you are using the Segate adapter instead of the Samsung?
June 18th, 2025, 16:05
Thanks for the responses.
I am definitely using the Samsung adapter. I just found out from the End User that the drive went to a computer shop before it came to me, so I decided to look at the PCB under magnification (which I should've done right away) and I see now that many components are missing, probably knocked off by the people who looked at the drive before me. That would explain why Terminal is not working. I ordered a donor and I guess I'll just have to move the ROM chip from the patient to the donor PCB. Thanks for trying to help, it's much appreciated.
