 Post subject: where can i get new hard drive circuit boards?
PostPosted: July 25th, 2005, 1:52
does anyone know where i can find a hard drive circuit board for my hard drive? it is shot and i need to recover the data. my info is as follows incase anyone has an old drive they wouldnt mind getting rid of or can steer me in the right direction... i did check ebay and have been searching on google for the past 2 hours with no luck.
MDL: WD1000BB-75CHE0
Date: 19 NOV 2001
DCM: DSEHBT2AH
Firmware revision A00
please, someone help... there is a lot of really important data on this drive that i cannot afford to lose! thanks!
 Post subject:
PostPosted: July 25th, 2005, 15:18
did you try to find it on ebay.com ?
 Post subject:
PostPosted: July 25th, 2005, 15:51
almazlamaz:
jivemastert just said that he checked ebay ;-)
I would suggest to find exact the same drive and use its pcb... Or just repair the original pcb.
 Post subject: pcb
PostPosted: July 25th, 2005, 18:00
Date: 19 NOV 2001
DCM: DSEHBT2AH
this is not enough if no same pcb drive doesn't work
to carry and to save firmware seagate
 Post subject: Re: pcb
PostPosted: July 25th, 2005, 18:10
Date: 19 NOV 2001
DCM: DSEHBT2AH
wait, what do you mean? that's not enough info to track down another of the same logic board?
 Post subject:
PostPosted: July 25th, 2005, 18:11
Dmitry_Postrigan wrote:
almazlamaz:
how would i go about repairing the original pcb?
 Post subject: PCB
PostPosted: July 25th, 2005, 18:42
no unhappily not!
I have with me this WD1000BB-75CHE0
DCM: DSEHBT2AH
Date: 21 OCT 2001
IN PCB HAS THAT NUMBER
2060-001092-006
LOOK AT THAT
 Post subject: Re: PCB
PostPosted: July 25th, 2005, 19:15
fabio wrote:
no unhappily not!
DCM: DSEHBT2AH
Date: 21 OCT 2001
2060-001092-006
LOOK AT THAT
the number on mine is 2060-001102-002
 Post subject:
PostPosted: July 25th, 2005, 19:27
almazlamaz:
Umm. Well, exactly how people do repair pcbs: find what is failed/fried and change it :-)
 Post subject:
PostPosted: July 25th, 2005, 21:58
almazlamaz:
i know i know... but like how do you find out what is fried? is it obvious by looking at it? i'm a total noob to this... drive failure isnt exactly something i deal with every day, so any help, links, guides, etc are appriciated. thanks!
 Post subject:
PostPosted: July 26th, 2005, 9:14
Usually WDs are failing with visible damage. If there is no visible damage to any chip, then have to figure out by using multimeter (or oscilloscope sometimes). It is impossible to give "service manual" for doing this, you should be familiar with this process :-).
I still think that there are big chances that you can find proper drive for doing pcb swap.
 Post subject:
PostPosted: July 26th, 2005, 12:32
ok, so i took off the logic board and there is a chip one of the corners that has visible damage to it. i can't read the numbers on it because it melted. i am looking for a new board right now, posting everywhere, asking everyone... apparently my drive is a special one that was made for dell, so the first half of the model number designates it as a 2mb cache, 100gb drive. the second half of the model number designates it as having a special edition 8mb cache. please check your drives if you have a 100gb wd drive! i would even pay to just rent your logic board from you! thanks!
 Post subject:
PostPosted: July 26th, 2005, 13:47
Usually it is enough to change that chip. The chip is L6278, so just change it and probably the drive will work again.
 Post subject:
PostPosted: July 26th, 2005, 20:10
you're right... that is exactly the chip that it is. I am having a tough time finding someone who can sell me one... is there anyone you might reccomend? mine says L6278 1.2. Also, I am in the united states. thanks!
 Post subject:
PostPosted: July 26th, 2005, 21:35
This is spindle motor driver. I do not know where to buy such chip, but you can find that chip on many WD models.
Users browsing this forum: Google [Bot] and 82 guests
