 Post subject: Bad ROM FBLite
PostPosted: May 1st, 2026, 19:07
Drive received, likely with a bad head.
When connected over USB, it presents in a BSY state. It does not click, but it makes the typical sound of heads failing to read. I suspect that if I performed a head map change in RAM, I could likely pull a partial image.
PCB was removed and the ROM was extracted using normal soldering temperatures.
The ROM dump is the problem. The contents look completely irregular, and PC-3000 cannot interpret it. I reread it using a different programmer and received the same CRC.
I then reattached the ROM to the original USB PCB. The drive is now dead.
I can attempt a head swap and try to rebuild the ROM from SA - 4F may be a pain, but I’m curious if anyone has seen this before or has an opinion on what may have happened.
The only oddity I noticed is that the ROM chip is not the usual brand I commonly see on these drives, such as Winbond. I do not recall the exact part number, but I can get a screenshot if useful.
ROM attached.
rom.zip [58.64 KiB]
Downloaded 140 times
 Post subject: Re: Bad ROM FBLite
PostPosted: May 1st, 2026, 20:00
The second half is empty.
Analysing WO46657-2.bin ...
Searching for LDSCs and verifying PCMBlocks ...
LDSC   LDSC    Att   PCMBlock          RAM         size      PCMBlk CS
Start  ID CS        Start -  End     address     RAM / ROM    Exp/Act
    0  5A 63   02     100 -  2437      12800     2336  2336  6D0C 6D0C   OK
   20  01 4D   0C    2438 -  4CA4   88800000     286C  286C    CF   CF   OK
   40  02 65   01    4CA5 -  D051          0 c   ABB4  83AC    98   98   OK
   60  03 C6   01    D052 -  D6D6      117AC c    80C   684    87   87   OK
   80  04 22   03    D6D7 -  D8CB      80220 c    2A4   1F4    21   21   OK
   A0  05 E0   03    D8CC -  DABC   10157200 c    304   1F0    2C   2C   OK
   C0  06 AA   01    DABD - 24EB5   90347E00 c  1ED50 173F8    FF   4E   BAD
   E0  07 EF   01   24EB6 - 3DCD2   90006E30 c  23370 18E1C    FF   E4   BAD
LDSC   = PM Loader Config String (32 bytes)
ID     = ID byte of LDSC (byte #0)
CS     = Checksum byte or word
Att    = Attributes
PCMBlk = Program Code Memory Block
Exp    = Expected checksum for PCMBLock
Act    = Actual checksum for PCMBLock
c      = compressed PCMBlock
size   = size of decompressed (in RAM) and compressed (in ROM) PCMBlock in bytes
No ROYL directory modules (0x0B or 0x20B) found in ROM
PostPosted: May 1st, 2026, 20:25
Thank you; - how in the heck does that just "happen".
Sigh...
PostPosted: May 2nd, 2026, 4:35
i would suspect intentional abuse, but who knows... If it is a poor quality flash... However, it is odd to have not only bit errors but complete erasure of blocks.
I wrote some prog to help recovering 4f quite some yrs ago, so i can do that but need physical access to the drive.
PostPosted: May 5th, 2026, 22:58
Thanks Pepe; was able to rebuild 4F with a donor MHA - lucky donor... However drive was completely messed up.
02 contained (what I think was purposeful FF) in critical area's there there was jibberish in 109. I have no idea what this case was about. It's one of those cases that even if you knew the history you still would not care.
Your gut was right.
PostPosted: May 10th, 2026, 10:59
I figure this disk is far past the best before date
It does suggest some logic problems
Users browsing this forum: yellowbrickdr and 261 guests
