Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
 Post subject: Re: pipeline hd .2 st3160316cs (P) SATA Reset / SIM Error 1
PostPosted: August 4th, 2026, 13:16
After 58109 hours, I suspect the ST3160316CS has gone past the best before date.
Copy any remaining data and retire the old disk
PostPosted: August 4th, 2026, 13:31
thank you @swm , after you pin correction i went to verify again about the 5v pin which many said not to ever plug anything in it as its high voltage and might damage the usb cp210 or pch chip ! this fear lead me to too much of workaround and tough journey somehow making the hdd work again , its all good and fine now .
i learned about the 5v pin as rx you said and its 5v because its due to some pull up resistor and can be plugged , nothing will happen with non human interaction with proofs and validity - i plugged with my eyes closed sweating ! -- the psata ,asci diag came up ! :shock: :idea: i clicked ztlevel in f3st comexmaple - it worked ! . as nothing to do in it as the hdd started to work as usual - i went to check hows the service area is -- F3 7>m this gave a lots of fast big txt with cylinder and end
Idx Cylinder Hd count flags count count lba lba lb
count count lba lba lba lba
1D E78E 0 A0
a lba
1D E78E 0 A0 0 3F 0 7FFEBF1 7FFF44D
0 3F 0 7FFEBF1 7FFF44D 7FFFCAB 8000507
127 E7C5 0
7FFFCAB 8000507
127 E7C5 0 9C 0 6D 40 FFFFFFFF
9C 0 6D 40 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF and stuffs .
then did this
F3 2>x
User Partition
LBAs 00000000-12A19EAF
PBAs 00000000-12DC52
User Partition
PBAs 00000000-12DC5291
HdSkew 006E, CylSkew 002D
ZonesPerHd 11
Head 0, PhyCyls 000000-028728, LogCyls 0000
91
ZonesPerHd 11
Head 0, PhyCyls 000000-028728, LogCyls 000000-027B59
Physical Logical Sec Sym Sym Data
Zn Cylinder
00-027B59
Zn Cylinders Cylinders Track Wedge Track Rate
00 000000-0002BB 000000-0002BB 09A0
00 000000-0002BB 000000-0002BB 09A0 0DB3 00130D20 1299.375
01 0002BC-005249 0002BC-005249 092A 0D29 00124F60 12
01 0002BC-005249 0002BC-005249 092A 0D29 00124F60 1248.750
02 00524A-006E84 00524A-006E84 0913 0D08 001224C0 1237.500
03 006E85-
48.750
03 006E85-00987C 006E85-00987C 08CC 0C9D 001191A0 1198.125
04 00987D-00BDCE 00987D-00BDCE
04 00987D-00BDCE 00987D-00BDCE 0886 0C36 00110400 1160.625
05 00BDCF-00EFB5 00BDCF-00EFB5 085D 0C02 0010BDE0 1141
05 00BDCF-00EFB5 00BDCF-00EFB5 085D 0C02 0010BDE0 1141.875
06 00EFB6-011AC6 00EFB6-011AC6 0814 0B9C 00103040 1104.375
07 011AC7-01
.875
07 011AC7-01503B 011AC7-01503B 07B3 0B0C 000F6BA0 1051.875
08 01503C-017174 01503C-017174 0780
08 01503C-017174 01503C-017174 0780 0AC9 000F0F80 1027.500
09 017175-019AE1 017175-019AE1 0738 0A5A 000E7580 986.250
0A 019AE2-01BDBE 019AE2-01BDBE 06E0 09C4 000DA8A0 931.875
0B 01BDBF-01E915 01BDBF-01
0B 01BDBF-01E915 01BDBF-01E915 0688 095E 000D1C60 894.375
0C 01E916-020378 01E916-020378 0643 0902 000C9DE0 86
0C 01E916-020378 01E916-020378 0643 0902 000C9DE0 860.625
0D 020379-022678 020379-022678 05F5 088C 000BFBA0 817.500
0E 022679-0245
0.625
0E 022679-024504 022679-024504 0599 080F 000B4D00 770.625
0F 024505-026A9A 024505-026A9A 0531 077
0F 024505-026A9A 024505-026A9A 0531 077A 000A8020 716.250
10 026A9B-028728 026A9B-028728 04F8 072C 000A1640 688.125
Sys
A 000A8020 716.250
System Partition
LBAs 00000000-0004C3F7
PBAs 00000000-0004CB2F
tem Partition
HdSkew 006E, CylSkew 0018
ZonesPerHd 02
Head 0, PhyCyls 028729-02887C, LogCyls 000000-000152
Physical
18
ZonesPerHd 02
00 028729-0287D2 000000-0000A9 039C 0529 00074880 496.875
ge Track Rate
01 0287D3-02887C 0000AA-000153 039C 0529 00074880 496.875
F3 2>
01 0287D3-02887C 0000AA-000153 039C 0529 00074880 496.875 so then took off everything now . will use this drive as casual movie or cache disk as it was already been used that way . thank you so much for the help everyone .. the f3rom explorer , python script by fzkbar sir , swm sir ,lukas sir . and non human interface/usb sata ide converter- which explained taught me a lots and rredit forums .
it seems the patched rom have unlocked the whole features which was not there in reburbished patch ..so will continue to use it or learn it more.
PostPosted: August 6th, 2026, 0:17
wanted to document this -summary of my journey almost 10 days
CP2102/CH341A to patch the ROM ,f3romexplorer ,python script of fzabkar sir for crc count,shorting pins sata ide usb converter --- PSATA (Safe Mode) back into full HSATA over the USB bridge, the drive came alive with all partitions and data intact smooth as it was before.
checked with 100mb rar file copy cut paste . all fine .
SMART initially flagged 9 pending sectors - used ttl v4 to see those strings , then converted them to lba to read remap erase through victoria - windows 7 64bit ult . if want data intact and dont have much space to save the whole drive ---
but first had to see which files are related to those exact bad sector with 1 block size .
used fsutil cmd prompt in windows , copied only that file to pendrive , shift del from drive , then remapped /erased the sector , then copied back the files to thier original place with data speed upto 18-23MBPS in usb2.0 . remapping erasing permission denied - so have to remove drive letter, swtich off mbr , disbale drive , enable drive again , then try first erase then remap .
bad clus will come if the sector was not occupied by any files . pending sector will be shot down one by one the moment they get remap or erased . and i got good in crystal diskinfo/disgenious yay! :o :shock: :D
forgot this - last step for me would be to desolder those thin transformer wires from rom legs in drive pcb off which was used for attaching to ch431a pro for flashing atleast 7-10 times these days . learnt a lots , right wrong all ..thank you everyone .
PostPosted: August 6th, 2026, 3:43
this thing was very strange for me, the patched rom you sent is crazy, it should not be working at all, coz SAP segment is changed without correcting the crc, the other patch is in the unused area of the CFW segment, has no effect. :roll:
PostPosted: August 6th, 2026, 7:07
hello sir @pepe , yes in rom explorer it shows bad ,this was the python patch used to the original rom bin -
import os
def calculate_seagate_checksum16(buffer: bytearray) -> int:
"""Calculates the native Seagate F3 16-bit additive checksum."""
total_sum = 0
for i in range(0, len(buffer), 2):
if i + 1 < len(buffer):
word = buffer[i] | (buffer[i+1] << 8)
total_sum = (total_sum + word) & 0xFFFF
return (0x0000 - total_sum) & 0xFFFF
def build_terminal_only_step(input_bin, output_bin):
if not os.path.exists(input_bin):
print(f"[-] Error: Source file '{input_bin}' not found.")
return
with open(input_bin, 'rb') as f:
rom = bytearray(f.read())
print("[+] Loading clean factory baseline file...")
print("[+] STEP 1: Preserving 100% of motor and platter configurations.")
# 1. FORCE THE SERIAL TERMINAL TO UNLOCK
# We modify ONLY these two bytes at the diagnostic interface table boundary.
# This leaves the motor code fully operational while unblocking the serial interface.
rom[0x61600] = 0x00
rom[0x61601] = 0x00
print("[+] Modified diagnostic handshake registers to open status.")
# 2. RECALCULATE GLOBAL CONTAINER CHECKSUM
print("[+] Re-aligning global microcode container check parameters...")
active_data_end = 0x7E000
global_master_sum = calculate_seagate_checksum16(rom[:active_data_end])
rom[active_data_end - 4] = global_master_sum & 0xFF
rom[active_data_end - 3] = (global_master_sum >> 8) & 0xFF
rom[active_data_end - 2] = 0x55
rom[active_data_end - 1] = 0xAA
print(f" -> Master Container integrity aligned (New Checksum: {hex(global_master_sum)})")
with open(output_bin, 'wb') as f:
f.write(rom)
print(f"\n[SUCCESS] Step 1 Terminal-Ready ROM Generated: {output_bin}")
if __name__ == '__main__':
build_terminal_only_step("original.bin", "patched_step1.bin")
, it was giving the same sim error ,203c , i dint put sata data cable all this time while troubleshooting, so i tried it all once again as was doing before , shorting pins , then trying for automation ctrlz , nothing came, may be if i had put right pin in 5v - i might have got it right them . but discussion with gemi (non human) siad i would have needed this rom patch anyways , well i am a newbie in all this , the first time ever for everything i did . so then shorting pins,nothing happen , then i read somewhere sim error or r203c , cable attached detached is like its searching for sata input , so i thought to put sata usb thing lying around instead of doing the mobo straight away . then sudenly p sata changed to h sata , everything worked as before. then i chekd with mobo sata data cable straight away , it detected too , no stuck nothing , booted up well. mm but i put only one patch rom here, other one first i uploaded is the rom i had from refurbished time , i mean the rom i took backup from my drive . before i started doing patchy to rom. patched_step1 - Copy.rar [429.67 KiB] this is only one patched i uplaoded here. some rom patch i tried gave bogus rain csfr . some just straight away gave 2002 , some same sim error and stufs . this patched_step1 - Copy.rar [429.67 KiB] - somehow was a part of combo things done when dirve woke when usb sata ide was pushed. in none other patches i did the usb sata push . because earlier when i tried to do the usb sata ide - it was similiar to hdd light being solid , and nothing happend. not detecting. so my aim was to bring the f3t asci diag automatically with the patch right after plugging the sata power cable with ctrlz automation or without it. so instructed gemi to make such a patch bypassing everyting .. it was more than 7-8 trials , kept trying one by one.. dono much.. i just did all this very superficially .
PostPosted: August 6th, 2026, 7:22
that script is bs.
offsets are not fixed like that in the code and the crc is calculated way differently.
:shock:
AI does miracles, surely...
PostPosted: August 6th, 2026, 7:48
https://ibb.co/fG4SqR37 my spidy rom for ch34a pins , dono if i could put it here.. just wanted to share :)
Don't look for meaning where there is none... :?
PostPosted: August 6th, 2026, 10:18
i did some terminal commands before - please see if they are okish ..
F3 T>V10
P List
phy phy log length
head cyl cyl in symb SFI flags
0 156F 156F 38A 9376C 80 scr fill
0 1570 1570 38A 9376C 80 scr fill
0 1571 1571 38A 9376C 80 scr fill
0 18E3 18E3 DD 2E449 80 scr fill
0 18E4 18E4 DD 2E44B 80 scr fill
0 18E5 18E5 DD 2E44D 80 scr fill
0 18E6 18E6 DD 2E44F 80 scr fill
0 18E7 18E7 DD 2E451 80 scr fill
0 18E8 18E8 DD 2E453 80 scr fill
0 1CB1 1CB1 E2 12435C 80 scr fill
0 1CB2 1CB2 E2 12435C 80 scr fill
0 1CB3 1CB3 E2 12435C 80 scr fill
0 1CB4 1CB4 E2 12435C 80 scr fill
0 1CB5 1CB5 E2 12435C 80 scr fill
0 1CB6 1CB6 E2 12435C 80 scr fill
0 1CB7 1CB7 E2 12435C 80 scr fill
0 1CB8 1CB8 E2 12435C 80 scr fill
0 1CB9 1CB9 E2 12435C 80 scr fill
0 1CBA 1CBA E2 12435C 80 scr fill
0 1CBB 1CBB E2 12435C 80 scr fill
0 1CBC 1CBC E2 12435C 80 scr fill
0 1CBD 1CBD E2 12435C 80 scr fill
0 1CBE 1CBE E2 12435C 80 scr fill
0 1CBF 1CBF E2 12435C 80 scr fill
0 227B 227B DD 1B7AB 80 scr fill
0 227C 227C DD 1B7AA 80 scr fill
0 227D 227D DD 1B7A9 80 scr fill
0 227E 227E DD 1B7A8 80 scr fill
0 227F 227F DD 1B7A7 80 scr fill
0 2280 2280 DD 1B7A6 80 scr fill
0 2503 2503 38A 71425 80 scr fill
P List
phy phy log length
0 2504 2504 38A 71425 80 scr fill
0 2505 2505 38A 71425 80 scr fill
0 2565 2565 390 65AF4 80 scr fill
0 2566 2566 390 65AF4 80 scr fill
0 2567 2567 390 65AF4 80 scr fill
0 2630 2630 38A 4FB89 80 scr fill
0 2631 2631 38A 4FB89 80 scr fill
0 2632 2632 38A 4FB89 80 scr fill
0 2E65 2E65 390 FE26 80 scr fill
0 2E66 2E66 390 FE26 80 scr fill
0 2E67 2E67 390 FE26 80 scr fill
0 35C2 35C2 38A 10BE6F 80 scr fill
0 35C3 35C3 38A 10BE6F 80 scr fill
0 35C4 35C4 38A 10BE6F 80 scr fill
0 3ACD 3ACD 38A 567FB 80 scr fill
0 3ACE 3ACE 38A 567FB 80 scr fill
0 3ACF 3ACF 38A 567FB 80 scr fill
0 5077 5077 E4 121164 80 scr fill
0 5078 5078 E4 121164 80 scr fill
0 5079 5079 E4 121163 80 scr fill
0 507A 507A E4 121163 80 scr fill
0 507B 507B E4 121162 80 scr fill
0 507C 507C E4 121162 80 scr fill
0 5729 5729 38A 1621E 80 scr fill
0 572A 572A 38A 1621E 80 scr fill
0 572B 572B 38A 1621E 80 scr fill
0 5A9D 5A9D 390 8BDA3 80 scr fill
0 5A9E 5A9E 390 8BDA3 80 scr fill
0 5A9F 5A9F 390 8BDA3 80 scr fill
0 6248 6248 DD D9162 80 scr fill
0 6249 6249 DD D9162 80 scr fill
P List
phy phy log length
0 624A 624A DD D9162 80 scr fill
0 624B 624B DD D9162 80 scr fill
0 624C 624C DD D9162 80 scr fill
0 624D 624D DD D9162 80 scr fill
0 828F 828F 390 769AA 80 scr fill
0 8290 8290 390 769AA 80 scr fill
0 8291 8291 390 769AA 80 scr fill
0 851B 851B 390 9F0D4 80 scr fill
0 851C 851C 390 9F0D4 80 scr fill
0 851D 851D 390 9F0D4 80 scr fill
0 8AE3 8AE3 DD 3B9F6 80 scr fill
0 8AE4 8AE4 DD 3B9F5 80 scr fill
0 8AE5 8AE5 DD 3B9F3 80 scr fill
0 8AE6 8AE6 DD 3B9F2 80 scr fill
0 8AE7 8AE7 DD 3B9F0 80 scr fill
0 8AE8 8AE8 DD 3B9EF 80 scr fill
0 9657 9657 38A FB464 80 scr fill
0 9658 9658 38A FB464 80 scr fill
0 9659 9659 38A FB464 80 scr fill
0 9D03 9D03 390 B6824 80 scr fill
0 9D04 9D04 390 B6824 80 scr fill
0 9D05 9D05 390 B6824 80 scr fill
0 BF23 BF23 E9 262AB 80 scr fill
0 BF24 BF24 E9 262AB 80 scr fill
0 BF25 BF25 E9 262AC 80 scr fill
0 BF26 BF26 E9 262AC 80 scr fill
0 BF27 BF27 E9 262AD 80 scr fill
0 BF28 BF28 E9 262AD 80 scr fill
0 BF29 BF29 E9 262AE 80 scr fill
0 BF2A BF2A E9 262AE 80 scr fill
0 BF2B BF2B E9 262AF 80 scr fill
P List
phy phy log length
0 BF2C BF2C E9 262AF 80 scr fill
0 BF2D BF2D E9 262B0 80 scr fill
0 BF2E BF2E E9 262B0 80 scr fill
0 BF2F BF2F E9 262B1 80 scr fill
0 BF30 BF30 E9 262B1 80 scr fill
0 BF31 BF31 E9 262B2 80 scr fill
0 C977 C977 390 64A4 80 scr fill
0 C978 C978 390 64A4 80 scr fill
0 C979 C979 390 64A4 80 scr fill
0 D621 D621 DD 632D7 80 scr fill
0 D622 D622 DD 632D6 80 scr fill
0 D623 D623 DD 632D6 80 scr fill
0 D624 D624 DD 632D5 80 scr fill
0 D625 D625 DD 632D5 80 scr fill
0 D626 D626 DD 632D4 80 scr fill
0 E921 E921 38A 7A552 80 scr fill
0 E922 E922 38A 7A552 80 scr fill
0 E923 E923 38A 7A552 80 scr fill
0 EBB1 EBB1 396 44595 80 scr fill
0 EBB2 EBB2 396 44595 80 scr fill
0 EBB3 EBB3 396 44595 80 scr fill
0 EEAB EEAB 390 87A23 80 scr fill
0 EEAC EEAC 390 87A23 80 scr fill
0 EEAD EEAD 390 87A23 80 scr fill
0 105E5 105E5 DD A9ECE 80 scr fill
0 105E6 105E6 DD A9ECE 80 scr fill
0 105E7 105E7 DD A9ECD 80 scr fill
0 105E8 105E8 DD A9ECD 80 scr fill
0 105E9 105E9 DD A9ECC 80 scr fill
0 105EA 105EA DD A9ECC 80 scr fill
0 105EB 105EB DD A9ECB 80 scr fill
P List
phy phy log length
0 105EC 105EC DD A9ECB 80 scr fill
0 105ED 105ED DD A9ECA 80 scr fill
0 105EE 105EE DD A9ECA 80 scr fill
0 105EF 105EF DD A9EC9 80 scr fill
0 105F0 105F0 DD A9EC9 80 scr fill
0 105F1 105F1 DD A9EC8 80 scr fill
0 105F2 105F2 DD A9EC8 80 scr fill
0 105F3 105F3 DD A9EC7 80 scr fill
0 1116A 1116A D6 B3C2B 80 scr fill
0 1116B 1116B D6 B3C2B 80 scr fill
0 1116C 1116C D6 B3C2B 80 scr fill
0 1116D 1116D D6 B3C2B 80 scr fill
0 1116E 1116E D6 B3C2B 80 scr fill
0 1116F 1116F D6 B3C2B 80 scr fill
0 1155C 1155C 38A 8FD29 80 scr fill
0 1155D 1155D 38A 8FD29 80 scr fill
0 1155E 1155E 38A 8FD29 80 scr fill
0 1165D 1165D 38A FD451 80 scr fill
0 1165E 1165E 38A FD451 80 scr fill
0 1165F 1165F 38A FD451 80 scr fill
0 11756 11756 390 67478 80 scr fill
0 11757 11757 390 67478 80 scr fill
0 11758 11758 390 67478 80 scr fill
0 1202D 1202D D6 53AB 80 scr fill
0 1202E 1202E D6 53AC 80 scr fill
0 1202F 1202F D6 53AD 80 scr fill
0 12030 12030 D6 53AE 80 scr fill
0 12031 12031 D6 53AF 80 scr fill
0 12032 12032 D6 53B0 80 scr fill
0 12077 12077 38A 33AA 80 scr fill
0 12078 12078 38A 33AA 80 scr fill
P List
phy phy log length
0 12079 12079 38A 33AA 80 scr fill
0 1327D 1327D 38A EAB02 80 scr fill
0 1327E 1327E 38A EAB02 80 scr fill
0 1327F 1327F 38A EAB02 80 scr fill
0 1369B 1369B E4 770 80 scr fill
0 1369C 1369C E4 770 80 scr fill
0 1369D 1369D E4 76F 80 scr fill
0 1369E 1369E E4 76F 80 scr fill
0 1369F 1369F E4 76E 80 scr fill
0 136A0 136A0 E4 76E 80 scr fill
0 137A4 137A4 F2 43E78 80 scr fill
0 137A5 137A5 F2 43E78 80 scr fill
0 137A6 137A6 F2 43E78 80 scr fill
0 137A7 137A7 F2 43E78 80 scr fill
0 137A8 137A8 F2 43E78 80 scr fill
0 137A9 137A9 F2 43E78 80 scr fill
0 137AA 137AA F2 43E78 80 scr fill
0 137AB 137AB F2 43E78 80 scr fill
0 137AC 137AC F2 43E78 80 scr fill
0 137AD 137AD F2 43E78 80 scr fill
0 137AE 137AE F2 43E78 80 scr fill
0 137AF 137AF F2 43E78 80 scr fill
0 137B0 137B0 F2 43E78 80 scr fill
0 137B1 137B1 F2 43E78 80 scr fill
0 137B2 137B2 F2 43E78 80 scr fill
0 13914 13914 ED D6E6A 80 scr fill
0 13915 13915 ED D6E6A 80 scr fill
0 13916 13916 ED D6E6A 80 scr fill
0 13917 13917 ED D6E6B 80 scr fill
0 13918 13918 ED D6E6B 80 scr fill
0 13919 13919 ED D6E6B 80 scr fill
P List
phy phy log length
0 1391A 1391A ED D6E6B 80 scr fill
0 1391B 1391B ED D6E6C 80 scr fill
0 1391C 1391C ED D6E6C 80 scr fill
0 1391D 1391D ED D6E6C 80 scr fill
0 1391E 1391E ED D6E6C 80 scr fill
0 1391F 1391F ED D6E6D 80 scr fill
0 13920 13920 ED D6E6D 80 scr fill
0 13921 13921 ED D6E6D 80 scr fill
0 13922 13922 ED D6E6D 80 scr fill
0 1418A 1418A DD 76CC5 80 scr fill
0 1418B 1418B DD 76CC6 80 scr fill
0 1418C 1418C DD 76CC6 80 scr fill
0 1418D 1418D DD 76CC7 80 scr fill
0 1418E 1418E DD 76CC7 80 scr fill
0 1418F 1418F DD 76CC8 80 scr fill
0 14BC4 14BC4 38A E6B07 80 scr fill
0 14BC5 14BC5 38A E6B07 80 scr fill
0 14BC6 14BC6 38A E6B07 80 scr fill
0 1504D 1504D 390 34186 80 scr fill
0 1504E 1504E 390 34186 80 scr fill
0 1504F 1504F 390 34186 80 scr fill
0 15848 15848 E6 6A1D1 80 scr fill
0 15849 15849 E6 6A1D1 80 scr fill
0 1584A 1584A E6 6A1D1 80 scr fill
0 1584B 1584B E6 6A1D1 80 scr fill
0 1584C 1584C E6 6A1D1 80 scr fill
0 1584D 1584D E6 6A1D1 80 scr fill
0 1584E 1584E E6 6A1D1 80 scr fill
0 1584F 1584F E6 6A1D1 80 scr fill
0 15850 15850 E6 6A1D1 80 scr fill
0 15851 15851 E6 6A1D1 80 scr fill
P List
phy phy log length
0 15852 15852 E6 6A1D1 80 scr fill
0 15853 15853 E6 6A1D1 80 scr fill
0 15854 15854 E6 6A1D1 80 scr fill
0 15855 15855 E6 6A1D1 80 scr fill
0 15856 15856 E6 6A1D1 80 scr fill
0 17842 17842 38A 92C6D 80 scr fill
0 17843 17843 38A 92C6D 80 scr fill
0 17844 17844 38A 92C6D 80 scr fill
0 17DD8 17DD8 396 42353 80 scr fill
0 17DD9 17DD9 396 42353 80 scr fill
0 17DDA 17DDA 396 42353 80 scr fill
0 18669 18669 390 E0080 80 scr fill
0 1866A 1866A 390 E0080 80 scr fill
0 1866B 1866B 390 E0080 80 scr fill
0 19060 19060 390 A44C2 80 scr fill
0 19061 19061 390 A44C2 80 scr fill
0 19062 19062 390 A44C2 80 scr fill
0 1956C 1956C 390 68E8B 80 scr fill
0 1956D 1956D 390 68E8B 80 scr fill
0 1956E 1956E 390 68E8B 80 scr fill
0 1A66B 1A66B 390 D4ACE 80 scr fill
0 1A66C 1A66C 390 D4ACE 80 scr fill
0 1A66D 1A66D 390 D4ACE 80 scr fill
0 1A7C4 1A7C4 390 CC181 80 scr fill
0 1A7C5 1A7C5 390 CC181 80 scr fill
0 1A7C6 1A7C6 390 CC181 80 scr fill
0 1B6F0 1B6F0 E7 21082 80 scr fill
0 1B6F1 1B6F1 E7 21082 80 scr fill
0 1B6F2 1B6F2 E7 21082 80 scr fill
0 1B6F3 1B6F3 E7 21082 80 scr fill
0 1B6F4 1B6F4 E7 21082 80 scr fill
P List
phy phy log length
0 1B6F5 1B6F5 E7 21082 80 scr fill
0 1B6F6 1B6F6 E7 21082 80 scr fill
0 1B6F7 1B6F7 E7 21082 80 scr fill
0 1B6F8 1B6F8 E7 21082 80 scr fill
0 1B6F9 1B6F9 E7 21082 80 scr fill
0 1B6FA 1B6FA E7 21082 80 scr fill
0 1B6FB 1B6FB E7 21082 80 scr fill
0 1B6FC 1B6FC E7 21081 80 scr fill
0 1B6FD 1B6FD E7 21081 80 scr fill
0 1B6FE 1B6FE E7 21081 80 scr fill
0 1B6FF 1B6FF E7 21081 80 scr fill
0 1B700 1B700 E7 21081 80 scr fill
0 1B701 1B701 E7 21081 80 scr fill
0 1B702 1B702 E7 21081 80 scr fill
0 1B703 1B703 E7 21081 80 scr fill
0 1B704 1B704 E7 21081 80 scr fill
0 1B705 1B705 E7 21081 80 scr fill
0 1B706 1B706 E7 21081 80 scr fill
0 1B707 1B707 E7 21081 80 scr fill
0 1B708 1B708 E7 21081 80 scr fill
0 1B709 1B709 E7 21081 80 scr fill
0 1BC25 1BC25 396 A5515 80 scr fill
0 1BC26 1BC26 396 A5515 80 scr fill
0 1BC27 1BC27 396 A5515 80 scr fill
0 1C094 1C094 DD 6D2E 80 scr fill
0 1C095 1C095 DD 6D2E 80 scr fill
0 1C096 1C096 DD 6D2D 80 scr fill
0 1C097 1C097 DD 6D2D 80 scr fill
0 1C098 1C098 DD 6D2C 80 scr fill
0 1C099 1C099 DD 6D2C 80 scr fill
0 1C4F4 1C4F4 38A 67344 80 scr fill
P List
phy phy log length
0 1C4F5 1C4F5 38A 67344 80 scr fill
0 1C4F6 1C4F6 38A 67344 80 scr fill
0 1D4F8 1D4F8 D6 BEA70 80 scr fill
0 1D4F9 1D4F9 D6 BEA70 80 scr fill
0 1D4FA 1D4FA D6 BEA70 80 scr fill
0 1D4FB 1D4FB D6 BEA70 80 scr fill
0 1D4FC 1D4FC D6 BEA70 80 scr fill
0 1D4FD 1D4FD D6 BEA70 80 scr fill
0 1D78C 1D78C DD AC7FF 80 scr fill
0 1D78D 1D78D DD AC7FE 80 scr fill
0 1D78E 1D78E DD AC7FE 80 scr fill
0 1D78F 1D78F DD AC7FD 80 scr fill
0 1D790 1D790 DD AC7FD 80 scr fill
0 1D791 1D791 DD AC7FC 80 scr fill
0 1ED96 1ED96 390 CB3B 80 scr fill
0 1ED97 1ED97 390 CB3B 80 scr fill
0 1ED98 1ED98 390 CB3B 80 scr fill
0 1F17C 1F17C 38A AF19 80 scr fill
0 1F17D 1F17D 38A AF19 80 scr fill
0 1F17E 1F17E 38A AF19 80 scr fill
0 1FA84 1FA84 390 7CC9B 80 scr fill
0 1FA85 1FA85 390 7CC9B 80 scr fill
0 1FA86 1FA86 390 7CC9B 80 scr fill
0 20367 20367 370E 471CC 8
0 20368 20368 1ADE 471CC 8
0 20368 20368 234 48CAA C G to P
0 20368 20368 19FC 48EDE 8
0 20369 20369 370E 471CC 8
0 21171 21171 39C 670F5 80 scr fill
0 21172 21172 39C 670F5 80 scr fill
0 21173 21173 39C 670F5 80 scr fill
P List
phy phy log length
0 21777 21777 390 ADCD9 80 scr fill
0 21778 21778 390 ADCD9 80 scr fill
0 21779 21779 390 ADCD9 80 scr fill
0 21F91 21F91 E7 BD128 80 scr fill
0 21F92 21F92 E7 BD127 80 scr fill
0 21F93 21F93 E7 BD127 80 scr fill
0 21F94 21F94 E7 BD127 80 scr fill
0 21F95 21F95 E7 BD126 80 scr fill
0 21F96 21F96 E7 BD126 80 scr fill
0 21F97 21F97 E7 BD126 80 scr fill
0 21F98 21F98 E7 BD125 80 scr fill
0 21F99 21F99 E7 BD125 80 scr fill
0 21F9A 21F9A E7 BD125 80 scr fill
0 21F9B 21F9B E7 BD124 80 scr fill
0 21F9C 21F9C E7 BD124 80 scr fill
0 21F9D 21F9D E7 BD123 80 scr fill
0 21F9E 21F9E E7 BD123 80 scr fill
0 21F9F 21F9F E7 BD123 80 scr fill
0 21FA0 21FA0 E7 BD122 80 scr fill
0 21FA1 21FA1 E7 BD122 80 scr fill
0 21FA2 21FA2 E7 BD122 80 scr fill
0 21FA3 21FA3 E7 BD121 80 scr fill
0 21FA4 21FA4 E7 BD121 80 scr fill
0 21FA5 21FA5 E7 BD121 80 scr fill
0 21FA6 21FA6 E7 BD120 80 scr fill
0 21FA7 21FA7 E7 BD120 80 scr fill
0 21FA8 21FA8 E7 BD120 80 scr fill
0 21FA9 21FA9 E7 BD11F 80 scr fill
0 21FAA 21FAA E7 BD11F 80 scr fill
0 24F69 24F69 E4 A24FC 80 scr fill
0 24F6A 24F6A E4 A24FC 80 scr fill
P List
phy phy log length
0 24F6B 24F6B E4 A24FC 80 scr fill
0 24F6C 24F6C E4 A24FC 80 scr fill
0 24F6D 24F6D E4 A24FC 80 scr fill
0 24F6E 24F6E E4 A24FC 80 scr fill
0 2503E 2503E 38A 1BA41 80 scr fill
0 2503F 2503F 38A 1BA41 80 scr fill
0 25040 25040 38A 1BA41 80 scr fill
0 28244 28244 38A 94B05 80 scr fill
0 28245 28245 38A 94B05 80 scr fill
0 28246 28246 38A 94B05 80 scr fill
0 283E4 283E4 38A 20153 80 scr fill
0 283E5 283E5 38A 20153 80 scr fill
0 283E6 283E6 38A 20153 80 scr fill
Head 0 Entries: 162
Total Entries: 162
V2
System Slip Defect List
log log log phys phys
LBA span cumm cyl hd sctr zn cyl sctr SFI
0 0 0 0 0 0 0 28729 0 FFFFFFFF 0
261FC 39C 39C AA 0 0 1 287D3 0 FFFFFFFF 26598
Head 0: entries 2 slips 39C
Total Entries 2 Total Slips 39C
F3 T>V4
Reassigned Sectors List
Original New log log log phy phy
LBA PBA cyl hd sctr zn cyl hd sctr SFI
870072 870072 E98 0 DA 1 E98 0 DA 71C4A BBM
90B6CA 90B6CA FA7 0 3BC 1 FA7 0 3BC D066E BBM
915EEB 915EEB FB9 0 6E9 1 FB9 0 6E9 69280 BBM
133438B 13343B1 2164 0 2A1 1 2164 0 2A1 E67D2 BBM
1334ACF 1334AF5 2165 0 BB 1 2165 0 BB CF47D BBM
7ACDA59 7ACDB27 DD9E 0 23B 5 DD9E 0 23B DBCE8 BBM
8CC862A 8CC8710 10097 0 1D8 6 10097 0 1D8 9A093 BBM
8F1555B 8F15641 10525 0 5F1 6 10525 0 5F1 CC791 BBM
95A8DA6 95A8EA9 1122C 0 1CD 6 1122C 0 1CD 1006A1 BBM
Alt Pending Total Alted Total
Entries Entries Entries Alts Alts
Head 0 9
Total 0 9 9 0 0
Total Alt Removals: 0
Checksum = 22C5
F3 T>r28
File Volume 3
File ID 028
File Copy Number 0
File Descriptor FD34D028
File Size 00092800
Byte Offset 00000000
Bytes to read 00092800
Drive is ready to send FILE_3_028_0 file.
Input Command Error
F3 T>
Head 00 Resistance 010D X28
V1
User Slip Defect List
LBA span cumm cyl hd sctr zn cyl sctr SFI PBA
0 0 0 0 0 0 0 0 0 3 0
C5B3F7 3 3 156F 0 619 0 156F 61C 93CDE C5B3FA
C5BBF2 3 6 1570 0 4ED 0 1570 4F0 93CDE C5BBF8
C5C3ED 3 9 1571 0 3C1 0 1571 3C4 93CDE C5C3F6
E55AE6 1 A 18E3 0 809 1 18E3 80A 2E5A9 E55AF0
E562E3 1 B 18E4 0 6DD 1 18E4 6DE 2E5A9 E562EE
E56AE0 1 C 18E5 0 5B1 1 18E5 5B2 2E5A9 E56AEC
E572DD 1 D 18E6 0 485 1 18E6 486 2E5A9 E572EA
E57ADA 1 E 18E7 0 359 1 18E7 35A 2E5A9 E57AE8
E582D7 1 F 18E8 0 22D 1 18E8 22E 2E5A9 E582E6
10832FB 2 11 1CB1 0 258 1 1CB1 25A 1245FE 108330C
1083AF7 2 13 1CB2 0 12C 1 1CB2 12E 1245FE 1083B0A
10842F3 2 15 1CB3 0 0 1 1CB3 2 1245FE 1084308
108541A 1 16 1CB4 0 7FF 1 1CB4 800 1244BA 1085430
1085C17 1 17 1CB5 0 6D3 1 1CB5 6D4 1244BA 1085C2E
1086414 1 18 1CB6 0 5A7 1 1CB6 5A8 1244BA 108642C
1086C11 1 19 1CB7 0 47B 1 1CB7 47C 1244BA 1086C2A
108740E 1 1A 1CB8 0 34F 1 1CB8 350 1244BA 1087428
1087C0B 1 1B 1CB9 0 223 1 1CB9 224 1244BA 1087C26
1088408 1 1C 1CBA 0 F7 1 1CBA F8 1244BA 1088424
108952F 2 1E 1CBB 0 8F5 1 1CBB 8F7 12456C 108954D
1089D2B 2 20 1CBC 0 7C9 1 1CBC 7CB 12456C 1089D4B
108A527 2 22 1CBD 0 69D 1 1CBD 69F 12456C 108A549
108AD23 2 24 1CBE 0 571 1 1CBE 573 12456C 108AD47
108B51F 2 26 1CBF 0 445 1 1CBF 447 12456C 108B545
13D4148 1 27 227B 0 398 1 227B 399 1B969 13D416F
13D4945 1 28 227C 0 26C 1 227C 26D 1B969 13D496D
13D5142 1 29 227D 0 140 1 227D 141 1B969 13D516B
13D593F 1 2A 227E 0 14 1 227E 15 1B969 13D5969
13D6A66 2 2C 227F 0 812 1 227F 814 1BA1C 13D6A92
13D7262 2 2E 2280 0 6E6 1 2280 6E8 1BA1C 13D7290
1547584 3 31 2503 0 58C 1 2503 58F 718EE 15475B5
1547D7F 3 34 2504 0 460 1 2504 463 718EE 1547DB3
154857A 3 37 2505 0 334 1 2505 337 718EE 15485B1
157F865 3 3A 2565 0 662 1 2565 665 65FE5 157F89F
157FED0 3 3D 2566 0 3A6 1 2566 3A9 65FE5 157FF0D
15806CB 3 40 2567 0 27A 1 2567 27D 65FE5 158070B
15F3C36 3 43 2630 0 5EE 1 2630 5F1 50058 15F3C79
15F4431 3 46 2631 0 4C2 1 2631 4C5 50058 15F4477
15F4A9C 3 49 2632 0 206 1 2632 209 50058 15F4AE5
1AA6E64 3 4C 2E65 0 273 1 2E65 276 1039C 1AA6EB0
1AA765F 3 4F 2E66 0 147 1 2E66 14A 1039C 1AA76AE
1AA7E5A 3 52 2E67 0 1B 1 2E67 1E 1039C 1AA7EAC
1EDEBAE 3 55 35C2 0 584 1 35C2 587 10C33F 1EDEC03
1EDF3A9 3 58 35C3 0 458 1 35C3 45B 10C33F 1EDF401
1EDFBA4 3 5B 35C4 0 32C 1 35C4 32F 10C33F 1EDFBFF
21C212D 2 5D 3ACD 0 43E 1 3ACD 440 56B93 21C218A
21C2929 2 5F 3ACE 0 312 1 3ACE 314 56B93 21C2988
21C3125 2 61 3ACF 0 1E6 1 3ACF 1E8 56B93 21C3186
2E2A824 2 63 5077 0 357 1 5077 359 121416 2E2A887
2E2B020 2 65 5078 0 22B 1 5078 22D 121416 2E2B085
2E2B81C 2 67 5079 0 FF 1 5079 101 121416 2E2B883
2E2C943 1 68 507A 0 8FE 1 507A 8FF 1212B1 2E2C9AB
2E2D140 1 69 507B 0 7D2 1 507B 7D3 1212B1 2E2D1A9
2E2D93D 1 6A 507C 0 6A6 1 507C 6A7 1212B1 2E2D9A7
31F9320 3 6D 5729 0 331 1 5729 334 1676F 31F938D
31F9B07 3 70 572A 0 208 2 572A 20B 1676F 31F9B77
31FA2EE 3 73 572B 0 DF 2 572B E2 1676F 31FA361
33EE6CF 3 76 5A9D 0 14D 2 5A9D 150 8C1C7 33EE745
33EEEB6 3 79 5A9E 0 24 2 5A9E 27 8C1C7 33EEF2F
33EFFB1 2 7B 5A9F 0 80F 2 5A9F 811 8C165 33F002C
3847C43 1 7C 6248 0 218 2 6248 219 D9315 3847CBF
384842C 1 7D 6249 0 EF 2 6249 F0 D9315 38484A9
3849528 1 7E 624A 0 8D9 2 624A 8DA D92B3 38495A6
3849D11 1 7F 624B 0 7B0 2 624B 7B1 D92B3 3849D90
384A4FA 1 80 624C 0 687 2 624C 688 D92B3 384A57A
384ACE3 1 81 624D 0 55E 2 624D 55F D92B3 384AD64
4A3CFE7 3 84 828F 0 43 2 828F 46 76ECD 4A3D06B
4A3E05D 2 86 8290 0 7F0 3 8290 7F2 76D41 4A3E0E3
4A3E807 2 88 8291 0 6D0 3 8291 6D2 76D41 4A3E88F
4BA3ACE 2 8A 851B 0 3A1 3 851B 3A3 9F493 4BA3B58
4BA4278 2 8C 851C 0 281 3 851C 283 9F493 4BA4304
4BA4A22 2 8E 851D 0 161 3 851D 163 9F493 4BA4AB0
4ED1724 2 90 8AE3 0 49D 3 8AE3 49F 3BC25 4ED17B4
4ED1ECE 2 92 8AE4 0 37D 3 8AE4 37F 3BC25 4ED1F60
4ED2678 2 94 8AE5 0 25D 3 8AE5 25F 3BC25 4ED270C
4ED2E22 2 96 8AE6 0 13D 3 8AE6 13F 3BC25 4ED2EB8
4ED35CC 2 98 8AE7 0 1D 3 8AE7 1F 3BC25 4ED3664
4ED4643 2 9A 8AE8 0 7CA 3 8AE8 7CC 3BC81 4ED46DD
551D93C 2 9C 9657 0 651 3 9657 653 FB840 551D9D8
551E0E6 2 9E 9658 0 531 3 9658 533 FB840 551E184
551E890 2 A0 9659 0 411 3 9659 413 FB840 551E930
58B4E6F 3 A3 9D03 0 71E 3 9D03 721 B6CEA 58B4F12
58B55DB 3 A6 9D04 0 607 3 9D04 60A B6CEA 58B5681
58B5D47 3 A9 9D05 0 4F0 4 9D05 4F3 B6CEA 58B5DF0
6ADEEC5 1 AA BF23 0 131 4 BF23 132 26464 6ADEF6F
6ADF60F 1 AB BF24 0 1F 4 BF24 20 263E6 6ADF6BA
6AE05B6 2 AD BF25 0 76A 4 BF25 76C 264B8 6AE0663
6AE0D00 1 AE BF26 0 659 4 BF26 65A 2643A 6AE0DAE
6AE144A 1 AF BF27 0 547 4 BF27 548 263BC 6AE14F9
6AE1B94 2 B1 BF28 0 435 5 BF28 437 26533 6AE1C45
6AE22DD 2 B3 BF29 0 323 5 BF29 325 264B8 6AE2390
6AE2A27 1 B4 BF2A 0 212 5 BF2A 213 2643A 6AE2ADB
6AE3171 1 B5 BF2B 0 100 5 BF2B 101 263BC 6AE3226
6AE4119 1 B6 BF2C 0 84C 5 BF2C 84D 2648E 6AE41CF
6AE46F6 1 B7 BF2D 0 5CD 5 BF2D 5CE 26410 6AE47AD
6AE4E40 2 B9 BF2E 0 4BB 5 BF2E 4BD 26587 6AE4EF9
6AE5589 2 BB BF2F 0 3A9 5 BF2F 3AB 26509 6AE5644
6AE5CD3 1 BC BF30 0 298 5 BF30 299 2648E 6AE5D8F
6AE641D 1 BD BF31 0 186 5 BF31 187 26410 6AE64DA
7044E7F 3 C0 C977 0 7B 5 C977 7E 69E5 7044F3F
7045E24 3 C3 C978 0 7C6 5 C978 7C9 68C2 7045EE7
704656D 2 C5 C979 0 6B5 5 C979 6B7 6844 7046632
76E39EF 2 C7 D621 0 231 5 D621 233 63562 76E3AB6
76E4138 2 C9 D622 0 11F 5 D622 121 634FA 76E4201
76E4882 1 CA D623 0 E 5 D623 F 63469 76E494C
76E5829 2 CC D624 0 759 5 D624 75B 63538 76E58F5
76E5E06 1 CD D625 0 4DB 5 D625 4DC 634BD 76E5ED3
76E6550 1 CE D626 0 3C9 5 D626 3CA 6343F 76E661E
80D25B6 2 D0 E921 0 701 5 E921 703 7A920 80D2686
80D2CFF 3 D3 E922 0 5EF 5 E922 5F2 7AA97 80D2DD2
80D3447 3 D6 E923 0 4DD 5 E923 4E0 7AA1C 80D351D
8229173 3 D9 EBB1 0 476 5 EBB1 479 44A70 822924C
82298BB 3 DC EBB2 0 364 5 EBB2 367 44A08 8229997
822A004 2 DE EBB3 0 253 5 EBB3 255 44977 822A0E2
83B76F6 3 E1 EEAB 0 52F 5 EEAB 532 87ECE 83B77D7
83B7E3E 3 E4 EEAC 0 41D 5 EEAC 420 87E50 83B7F22
83B8587 2 E6 EEAD 0 30C 5 EEAD 30E 87DD2 83B866D
8F75EB0 1 E7 105E5 0 46 5 105E5 47 AA0B3 8F75F97
8F76DCE 2 E9 105E6 0 751 5 105E6 753 AA179 8F76EB7
8F774D8 1 EA 105E7 0 649 5 105E7 64A AA02F 8F775C2
8F77BE3 1 EB 105E8 0 541 5 105E8 542 AA0F5 8F77CCE
8F782ED 1 EC 105E9 0 438 6 105E9 439 A9FAD 8F783D9
8F789F8 1 ED 105EA 0 330 6 105EA 331 AA071 8F78AE5
8F79102 2 EF 105EB 0 227 6 105EB 229 AA137 8F791F1
8F7980C 1 F0 105EC 0 11F 6 105EC 120 A9FED 8F798FC
8F79F17 1 F1 105ED 0 17 6 105ED 18 AA0B3 8F7A008
8F7AE35 2 F3 105EE 0 722 6 105EE 724 AA179 8F7AF28
8F7B53F 1 F4 105EF 0 61A 6 105EF 61B AA02F 8F7B633
8F7BC4A 1 F5 105F0 0 512 6 105F0 513 AA0F5 8F7BD3F
8F7C354 1 F6 105F1 0 409 6 105F1 40A A9FAD 8F7C44A
8F7CA5F 1 F7 105F2 0 301 6 105F2 302 AA071 8F7CB56
8F7D169 2 F9 105F3 0 1F8 6 105F3 1FA AA137 8F7D262
95472CB 2 FB 1116A 0 610 6 1116A 612 B3E9B 95473C6
95479D5 1 FC 1116B 0 508 6 1116B 509 B3D6B 9547AD1
95480DF 2 FE 1116C 0 3FF 6 1116C 401 B3E31 95481DD
95487E9 2 100 1116D 0 2F7 6 1116D 2F9 B3EDD 95488E9
9548EF3 1 101 1116E 0 1EF 6 1116E 1F0 B3DAD 9548FF4
95495FD 2 103 1116F 0 E6 6 1116F E8 B3E73 9549700
9745009 3 106 1155C 0 470 6 1155C 473 901E3 974510F
9745712 3 109 1155D 0 368 6 1155D 36B 902A9 974581B
9745E1A 3 10C 1155E 0 25F 6 1155E 262 90179 9745F26
97C6F1A 3 10F 1165D 0 776 6 1165D 779 FD93D 97C7029
97C7623 2 111 1165E 0 66E 6 1165E 670 FD7F3 97C7734
97C7D2C 3 114 1165F 0 565 6 1165F 568 FD8B9 97C7E40
98445A4 2 116 11756 0 294 6 11756 296 67821 98446BA
9844CAD 3 119 11757 0 18B 6 11757 18E 678E7 9844DC6
98453B6 3 11C 11758 0 83 6 11758 86 679AD 98454D2
9C9A58C 2 11E 1202D 0 55E 7 1202D 560 5658 9C9A6AA
9C9AC41 2 120 1202E 0 462 7 1202E 464 5658 9C9AD61
9C9B2F6 2 122 1202F 0 366 7 1202F 368 5658 9C9B418
9C9B9AB 2 124 12030 0 26A 7 12030 26C 5658 9C9BACF
9C9C060 2 126 12031 0 16E 7 12031 170 5658 9C9C186
9C9C715 2 128 12032 0 72 7 12032 74 5658 9C9C83D
9CBE0B6 3 12B 12077 0 6D6 7 12077 6D9 3883 9CBE1E1
9CBE76A 3 12E 12078 0 5DA 7 12078 5DD 3883 9CBE898
9CBEE1E 3 131 12079 0 4DE 7 12079 4E1 3883 9CBEF4F
A56A1A4 2 133 1327D 0 39B 7 1327D 39D EAEF1 A56A2D7
A56A859 2 135 1327E 0 29F 7 1327E 2A1 EAEF1 A56A98E
A56AF0E 2 137 1327F 0 1A3 7 1327F 1A5 EAEF1 A56B045
A765613 2 139 1369B 0 516 7 1369B 518 96E A76574C
A765CC8 2 13B 1369C 0 41A 7 1369C 41C 96E A765E03
A76637D 2 13D 1369D 0 31E 7 1369D 320 96E A7664BA
A766A32 2 13F 1369E 0 222 7 1369E 224 96E A766B71
A7670E7 2 141 1369F 0 126 7 1369F 128 96E A767228
A76779C 2 143 136A0 0 2A 7 136A0 2C 96E A7678DF
A7E4E91 2 145 137A4 0 555 7 137A4 557 44113 A7E4FD6
A7E5546 2 147 137A5 0 459 7 137A5 45B 44113 A7E568D
A7E5BFB 2 149 137A6 0 35D 7 137A6 35F 44113 A7E5D44
A7E62B0 2 14B 137A7 0 261 7 137A7 263 44113 A7E63FB
A7E6965 2 14D 137A8 0 165 7 137A8 167 44113 A7E6AB2
A7E701A 2 14F 137A9 0 69 7 137A9 6B 44113 A7E7169
A7E7E83 1 150 137AA 0 721 7 137AA 722 440A5 A7E7FD3
A7E8539 1 151 137AB 0 625 7 137AB 626 440A5 A7E868A
A7E8BEF 1 152 137AC 0 529 7 137AC 52A 440A5 A7E8D41
A7E92A5 1 153 137AD 0 42D 7 137AD 42E 440A5 A7E93F8
A7E995B 1 154 137AE 0 331 7 137AE 332 440A5 A7E9AAF
A7EA011 1 155 137AF 0 235 7 137AF 236 440A5 A7EA166
A7EA6C7 1 156 137B0 0 139 7 137B0 13A 440A5 A7EA81D
A7EAD7D 1 157 137B1 0 3D 7 137B1 3E 440A5 A7EAED4
A7EBBE6 1 158 137B2 0 6F4 7 137B2 6F5 44047 A7EBD3E
A895E9C 2 15A 13914 0 425 7 13914 427 D70CE A895FF6
A896551 2 15C 13915 0 329 7 13915 32B D70CE A8966AD
A896C06 2 15E 13916 0 22D 7 13916 22F D70CE A896D64
A8972BB 2 160 13917 0 131 7 13917 133 D70CE A89741B
A897970 2 162 13918 0 35 7 13918 37 D70CE A897AD2
A8987D9 1 163 13919 0 6ED 7 13919 6EE D7060 A89893C
A898E8F 1 164 1391A 0 5F1 7 1391A 5F2 D7060 A898FF3
A899545 1 165 1391B 0 4F5 7 1391B 4F6 D7060 A8996AA
A899BFB 1 166 1391C 0 3F9 7 1391C 3FA D7060 A899D61
A89A2B1 1 167 1391D 0 2FD 7 1391D 2FE D7060 A89A418
A89A967 1 168 1391E 0 201 7 1391E 202 D7060 A89AACF
A89B01D 1 169 1391F 0 105 7 1391F 106 D7060 A89B186
A89B6D3 1 16A 13920 0 9 7 13920 A D7060 A89B83D
A89C3EC 1 16B 13921 0 570 7 13921 571 D7002 A89C557
A89CAA2 1 16C 13922 0 474 7 13922 475 D7002 A89CC0E
ACA841C 2 16E 1418A 0 537 7 1418A 539 76F93 ACA858A
ACA8AD1 2 170 1418B 0 43B 7 1418B 43D 76F93 ACA8C41
ACA9186 2 172 1418C 0 33F 7 1418C 341 76F93 ACA92F8
ACA983B 2 174 1418D 0 243 7 1418D 245 76F93 ACA99AF
ACA9EF0 2 176 1418E 0 147 7 1418E 149 76F93 ACAA066
ACAA5A5 2 178 1418F 0 4B 7 1418F 4D 76F93 ACAA71D
B19407A 3 17B 14BC4 0 513 7 14BC4 516 E6F33 B1941F5
B19472E 3 17E 14BC5 0 417 7 14BC5 41A E6F33 B1948AC
B194DE2 3 181 14BC6 0 31B 7 14BC6 31E E6F33 B194F63
B3C2318 3 184 1504D 0 52 7 1504D 55 346B7 B3C249C
B3C311F 3 187 1504E 0 6DC 7 1504E 6DF 345A8 B3C32A6
B3C37A7 3 18A 1504F 0 5E7 7 1504F 5EA 3468F B3C3931
B77FEC0 1 18B 15848 0 183 8 15848 184 6A332 B78004B
B780549 2 18D 15849 0 8D 8 15849 8F 6A419 B7806D6
B781352 1 18E 1584A 0 718 8 1584A 719 6A30A B7814E0
B7819DB 2 190 1584B 0 622 8 1584B 624 6A3F1 B781B6B
B782064 1 191 1584C 0 52D 8 1584C 52E 6A2CE B7821F5
B7825A6 2 193 1584D 0 2F0 8 1584D 2F2 6A441 B782739
B782C2F 1 194 1584E 0 1FB 8 1584E 1FC 6A332 B782DC3
B7832B8 2 196 1584F 0 105 8 1584F 107 6A419 B78344E
B783941 1 197 15850 0 10 8 15850 11 6A30A B783AD8
B78474A 2 199 15851 0 69A 8 15851 69C 6A3F1 B7848E3
B784DD3 1 19A 15852 0 5A5 8 15852 5A6 6A2CE B784F6D
B78545D 1 19B 15853 0 4B0 8 15853 4B1 6A3B4 B7855F8
B785AE6 2 19D 15854 0 3BA 8 15854 3BC 6A491 B785C83
B78616F 1 19E 15855 0 2C5 8 15855 2C6 6A382 B78630D
B7867F8 2 1A0 15856 0 1CF 8 15856 1D1 6A469 B786998
C65EBA1 3 1A3 17842 0 522 8 17842 525 931D7 C65ED44
C65F1E9 3 1A6 17843 0 435 8 17843 438 9305A C65F38F
C65F832 3 1A9 17844 0 349 9 17844 34C 930D2 C65F9DB
C8E3D54 2 1AB 17DD8 0 40E 9 17DD8 410 4271B C8E3EFF
C8E439D 3 1AE 17DD9 0 321 9 17DD9 324 42793 C8E454B
C8E49E6 3 1B1 17DDA 0 235 9 17DDA 238 4280B C8E4B97
CCC110B 3 1B4 18669 0 115 9 18669 118 E0548 CCC12BF
CCC1754 3 1B7 1866A 0 29 9 1866A 2C E05C0 CCC190B
CCC24D5 2 1B9 1866B 0 675 9 1866B 677 E0458 CCC268E
D140151 3 1BC 19060 0 25B 9 19060 25E A4961 D14030D
D14079A 3 1BF 19061 0 16F 9 19061 172 A49D9 D140959
D140DE3 2 1C1 19062 0 83 9 19062 85 A485C D140FA4
D3871D5 3 1C4 1956C 0 447 9 1956C 44A 693FF D387399
D38781E 2 1C6 1956D 0 35B 9 1956D 35D 69283 D3879E4
D387E67 3 1C9 1956E 0 26E 9 1956E 271 6930F D388030
DAF282D 3 1CC 1A66B 0 F7 9 1A66B FA D4F3D DAF29F9
DAF2E29 3 1CF 1A66C 0 16 9 1A66C 19 D4F3D DAF2FF8
DAF3B05 3 1D2 1A66D 0 615 9 1A66D 618 D4F3D DAF3CD7
DB86D0E 3 1D5 1A7C4 0 201 A 1A7C4 204 CC61F DB86EE3
DB8730A 3 1D8 1A7C5 0 120 A 1A7C5 123 CC61F DB874E2
DB87906 3 1DB 1A7C6 0 3F A 1A7C6 42 CC61F DB87AE1
E20B9E4 1 1DC 1B6F0 0 60 A 1B6F0 61 21268 E20BBC0
E20C6C2 1 1DD 1B6F1 0 65F A 1B6F1 660 21268 E20C89F
E20CCC0 1 1DE 1B6F2 0 57E A 1B6F2 57F 21268 E20CE9E
E20D2BE 1 1DF 1B6F3 0 49D A 1B6F3 49E 21268 E20D49D
E20D8BC 1 1E0 1B6F4 0 3BC A 1B6F4 3BD 21268 E20DA9C
E20DEBA 1 1E1 1B6F5 0 2DB A 1B6F5 2DC 21268 E20E09B
E20E4B8 1 1E2 1B6F6 0 1FA A 1B6F6 1FB 21268 E20E69A
E20EAB6 1 1E3 1B6F7 0 119 A 1B6F7 11A 21268 E20EC99
E20F0B4 1 1E4 1B6F8 0 38 A 1B6F8 39 21268 E20F298
E20FD92 1 1E5 1B6F9 0 637 A 1B6F9 638 21268 E20FF77
E210390 1 1E6 1B6FA 0 556 A 1B6FA 557 21268 E210576
E21098E 1 1E7 1B6FB 0 475 A 1B6FB 476 21268 E210B75
E210F8C 1 1E8 1B6FC 0 394 A 1B6FC 395 21268 E211174
E21158A 1 1E9 1B6FD 0 2B3 A 1B6FD 2B4 21268 E211773
E211B88 1 1EA 1B6FE 0 1D2 A 1B6FE 1D3 21268 E211D72
E212186 1 1EB 1B6FF 0 F1 A 1B6FF F2 21268 E212371
E212784 1 1EC 1B700 0 10 A 1B700 11 21268 E212970
E213462 1 1ED 1B701 0 60F A 1B701 610 21268 E21364F
E213A60 1 1EE 1B702 0 52E A 1B702 52F 21268 E213C4E
E21405E 1 1EF 1B703 0 44D A 1B703 44E 21268 E21424D
E21465C 1 1F0 1B704 0 36C A 1B704 36D 21268 E21484C
E214C5A 1 1F1 1B705 0 28B A 1B705 28C 21268 E214E4B
E215258 1 1F2 1B706 0 1AA A 1B706 1AB 21268 E21544A
E215856 1 1F3 1B707 0 C9 A 1B707 CA 21268 E215A49
E216534 1 1F4 1B708 0 6C8 A 1B708 6C9 21268 E216728
E216B32 1 1F5 1B709 0 5E7 A 1B709 5E8 21268 E216D27
E448B16 3 1F8 1BC25 0 54C A 1BC25 54F A5A2D E448D0E
E449112 3 1FB 1BC26 0 46B A 1BC26 46E A5A2D E44930D
E44970E 3 1FE 1BC27 0 38A A 1BC27 38D A5A2D E44990C
E620DCA 2 200 1C094 0 621 B 1C094 623 6FCE E620FCA
E62137A 2 202 1C095 0 54B B 1C095 54D 6F4A E62157C
E62192B 1 203 1C096 0 476 B 1C096 477 6EC5 E621B2E
E621EDC 1 204 1C097 0 3A0 B 1C097 3A1 6E5D E6220E0
E62248D 2 206 1C098 0 2CA B 1C098 2CC 6FCE E622693
E622A3D 2 208 1C099 0 1F4 B 1C099 1F6 6F4A E622C45
E7E9F98 3 20B 1C4F4 0 4F9 B 1C4F4 4FC 67777 E7EA1A3
E7EA548 2 20D 1C4F5 0 424 B 1C4F5 426 6770F E7EA755
E7EAAF8 3 210 1C4F6 0 34E B 1C4F6 351 67880 E7EAD08
EE73549 2 212 1D4F8 0 92 B 1D4F8 94 BECD0 EE7375B
EE74182 1 213 1D4F9 0 645 B 1D4F9 646 BEC4C EE74395
EE74733 1 214 1D4FA 0 56F B 1D4FA 570 BEBC8 EE74947
EE74CE4 2 216 1D4FB 0 499 B 1D4FB 49B BED38 EE74EFA
EE75294 2 218 1D4FC 0 3C3 B 1D4FC 3C5 BECD0 EE754AC
EE75728 1 219 1D4FD 0 1D1 B 1D4FD 1D2 BEC4C EE75941
EF80DD6 1 21A 1D78C 0 288 B 1D78C 289 AC98B EF80FF0
EF81387 1 21B 1D78D 0 1B2 B 1D78D 1B3 AC923 EF815A2
EF81938 2 21D 1D78E 0 DC B 1D78E DE ACA94 EF81B55
EF81EE8 2 21F 1D78F 0 6 B 1D78F 8 ACA10 EF82107
EF82B21 1 220 1D790 0 5B9 B 1D790 5BA AC98B EF82D41
EF830D2 1 221 1D791 0 4E3 B 1D791 4E4 AC923 EF832F3
F86C830 3 224 1ED96 0 21A C 1ED96 21D D0A1 F86CA54
F86CDA3 3 227 1ED97 0 14D C 1ED97 150 D0A1 F86CFCA
F86D316 3 22A 1ED98 0 80 C 1ED98 83 D0A1 F86D540
F9F343F 3 22D 1F17C 0 500 C 1F17C 503 B405 F9F366C
F9F39B2 3 230 1F17D 0 433 C 1F17D 436 B405 F9F3BE2
F9F3F25 3 233 1F17E 0 366 C 1F17E 369 B405 F9F4158
FD7BFB6 3 236 1FA84 0 368 C 1FA84 36B 7D102 FD7C1EC
FD7C529 3 239 1FA85 0 29B C 1FA85 29E 7D102 FD7C762
FD7CA9C 3 23C 1FA86 0 1CE C 1FA86 1D1 7D102 FD7CCD8
100F63F0 1C 258 20367 0 242 C 20367 25E 4A922 100F6648
100F694A 1C 274 20368 0 175 C 20368 191 4A922 100F6BBE
100F6EA4 1C 290 20369 0 A8 C 20369 C4 4A922 100F7134
10630E51 3 293 21171 0 5E9 D 21171 5EC 67654 106310E4
10631380 3 296 21172 0 526 D 21172 529 67654 10631616
106318AF 3 299 21173 0 463 D 21173 466 67654 10631B48
1086EE77 2 29B 21777 0 45A D 21777 45C AE0AF 1086F112
1086F3A7 2 29D 21778 0 397 D 21778 399 AE0AF 1086F644
1086F8D7 2 29F 21779 0 2D4 D 21779 2D6 AE0AF 1086FB76
10B7309D 1 2A0 21F91 0 3A4 D 21F91 3A5 BD2BE 10B7333D
10B735CE 1 2A1 21F92 0 2E1 D 21F92 2E2 BD2BE 10B7386F
10B73AFF 1 2A2 21F93 0 21E D 21F93 21F BD2BE 10B73DA1
10B74030 1 2A3 21F94 0 15B D 21F94 15C BD2BE 10B742D3
10B74561 1 2A4 21F95 0 98 D 21F95 99 BD2BE 10B74805
10B75087 2 2A6 21F96 0 5CA D 21F96 5CC BD3FA 10B7532D
10B755B7 2 2A8 21F97 0 507 D 21F97 509 BD3FA 10B7585F
10B75AE7 2 2AA 21F98 0 444 D 21F98 446 BD3FA 10B75D91
10B76017 2 2AC 21F99 0 381 D 21F99 383 BD3FA 10B762C3
10B76547 2 2AE 21F9A 0 2BE D 21F9A 2C0 BD3FA 10B767F5
10B76A77 2 2B0 21F9B 0 1FB D 21F9B 1FD BD3FA 10B76D27
10B76FA7 2 2B2 21F9C 0 138 D 21F9C 13A BD3FA 10B77259
10B774D7 2 2B4 21F9D 0 75 D 21F9D 77 BD3FA 10B7778B
10B77FFC 2 2B6 21F9E 0 5A7 D 21F9E 5A9 BD35C 10B782B2
10B7852C 2 2B8 21F9F 0 4E4 D 21F9F 4E6 BD35C 10B787E4
10B78A5C 2 2BA 21FA0 0 421 D 21FA0 423 BD35C 10B78D16
10B78F8C 2 2BC 21FA1 0 35E D 21FA1 360 BD35C 10B79248
10B794BC 2 2BE 21FA2 0 29B D 21FA2 29D BD35C 10B7977A
10B798E8 2 2C0 21FA3 0 D4 D 21FA3 D6 BD35C 10B79BA8
10B79E18 2 2C2 21FA4 0 11 D 21FA4 13 BD35C 10B7A0DA
10B7A93E 1 2C3 21FA5 0 544 D 21FA5 545 BD2BE 10B7AC01
10B7AE6F 1 2C4 21FA6 0 481 D 21FA6 482 BD2BE 10B7B133
10B7B3A0 1 2C5 21FA7 0 3BE D 21FA7 3BF BD2BE 10B7B665
10B7B8D1 1 2C6 21FA8 0 2FB D 21FA8 2FC BD2BE 10B7BB97
10B7BE02 1 2C7 21FA9 0 238 D 21FA9 239 BD2BE 10B7C0C9
10B7C333 1 2C8 21FAA 0 175 D 21FAA 176 BD2BE 10B7C5FB
11C142D8 1 2C9 24F69 0 330 D 24F69 331 A2672 11C145A1
11C1475E 1 2CA 24F6A 0 286 D 24F6A 287 A2672 11C14A28
11C14BE4 1 2CB 24F6B 0 1DC D 24F6B 1DD A2672 11C14EAF
11C1506A 1 2CC 24F6C 0 132 D 24F6C 133 A2672 11C15336
11C154F0 1 2CD 24F6D 0 88 D 24F6D 89 A2672 11C157BD
11C15EA8 1 2CE 24F6E 0 510 D 24F6E 511 A26E5 11C16176
11C5944E 3 2D1 2503E 0 2E7 F 2503E 2EA 1BE81 11C5971F
11C598D2 3 2D4 2503F 0 23D F 2503F 240 1BE81 11C59BA6
11C59D56 3 2D7 25040 0 193 F 25040 196 1BE81 11C5A02D
Head 0: entries 15B slips 2D7
Total Entries 15B Total Slips 2D7
thank you , sorry they are so long.. fast txt .
PostPosted: August 6th, 2026, 11:39
Why did you introduce them? And what do they mean? The documentation on them is no longer a secret. :shock:
F3 T>r28
It's the right thing to do—preserve critical modules.
Input Command Error
But you couldn't save this... :(
Look for a terminal program that supports Y-modem. If you're unsure what you're talking about, Google is your friend. :)
PostPosted: August 6th, 2026, 11:57
F3 T>r28
Input Command Error
hmm i read taht its good to save them and verify them, i dono much , so giving it here .
oh i hav that file 03 028 , did that y modem thing but not sure if its really that one. will put it here.
FILE_3_028_0.rar [2.67 KiB]
Downloaded 23 times
Users browsing this forum: No registered users and 191 guests
