After a somewhat longer absence, I’ve recently tried the suggested steps. I reconnected the faulty drive to the Windows system and attempted to use the Victoria 537 application. Unfortunately, even after waiting for an extended period, the drive did not show up in Victoria (the app remained constantly in a "Not Responding" state, and I waited for as long as 30 minutes).
Next, I tested the approach suggested by ora. I switched back to OpenSuperClone and reinstalled the faulty drive internally via direct SATA into the old laptop.
I attempted the drive cloning process again, this time adjusting the Skip Threshold to 12000 ms (12 s) in the Clone Settings.
Observation: This time, the cloning process did not freeze, but it is quite slow. I ran a test run for about 1 hour (and then pressed STOP). During this time—if I am reading the process parameters correctly from the attached figure—about 1% of the data was processed. Around 8.63 GB of the drive was parsed/scanned, but only 119.4 KiB of data was actually written to bbc.bin (my chosen image file name).
So, after running the cloning system for a 1-hour test, the process didn't halt, but shouldn't there be roughly 7 GB of actual copied data in the bbc.bin file by now?
As some of you have already pointed out, the issue is very likely the Slow Response Bug.
It seems we are slowly moving towards executing the step: Patch Mod 02 (and possibly Patch Mod 32), as mentioned by ora and fzabkar. From what I have gathered in the available documentation, the software makes a minimal modification to the drive's firmware to "unlock" the copy process, allowing the drive to read without getting stuck in error-handling loops.
As I mentioned earlier, I will be cloning the entire contents of the faulty drive onto a new healthy drive via a USB 2.0 connection (there is no other option). Since USB 2.0 is already quite slow, applying this patch would hopefully allow us to extract the data in the shortest possible time with minimal "Slow Response" delays.
If the experts on this forum confirm that proceeding with Patch Mod 02 makes sense at this point, I would like to double-check the exact step-by-step procedure with you once more (I previously prepared a list of steps).
