October 5th, 2026, 14:01
October 5th, 2026, 14:12
and then ran Victoria on both HDs.
October 5th, 2026, 19:44
WebClaw wrote:and then ran Victoria on both HDs.
Why did you run a high intensive I/O program on data you define as critical?
If the data is truly critical, treat it as such.
Create a 1:1 image / clone of the healthy (Seagate) 4TB drive using a program like OpenSuperClone. Then rebuild the array to a new drive by assigning the drive you replaced (WD) as a hot spare in the BIOS.
October 5th, 2026, 21:44
October 6th, 2026, 12:59
WebClaw wrote:The actions you are performing will not silence the SMART warnings - so the output from your array will remain the same (in your case "critical"). The bad one is actually bad. That said, your next step is to perform a full SMART on the drive - so we can see all values; not just those which Victoria produced. This will likely provide proof of the claim.
October 6th, 2026, 13:12
How can you be certain the drive is 100% bad?
October 6th, 2026, 13:22
October 6th, 2026, 16:07
October 6th, 2026, 19:10
Hardcore Games wrote:RAID is passe which today is given over JBOD. RAID5 tolerates one failed disk while RAID6 tolerates two failed disks.
October 7th, 2026, 0:37
SWM wrote:Full SMART from the Victoria SMART tab. Special programs are used to read RAID disks under Windows. You cannot write to this disk or run CheckDisk. The data will be corrupted.
***Create SMART Log file for RAIDXpert2 ***
Disk 0 ( 0, 0): WDC WD4000FYYZ-05UL1B0
10/06/2026 11:30:35 PM
SMART ATTRIBUTES: Version 16
- Attribute ID: 0x01 (Raw Read Error Rate ),
Threshold Value: 000,
Current Value: 200 (Always Passing ),
Raw Value: 175
- Attribute ID: 0x03 (Spinup Time ),
Current Value: 232 (Always Passing ),
Raw Value: 7391
- Attribute ID: 0x04 (Spinup Count ),
Current Value: 100 (Always Passing ),
Raw Value: 323
- Attribute ID: 0x05 (Reallocation Count ),
Current Value: 187 (Always Passing ),
Raw Value: 422
- Attribute ID: 0x07 (Seek Error Rate ),
Raw Value: 0
- Attribute ID: 0x09 (Poweron Time (Hours) ),
Current Value: 075 (Always Passing ),
Raw Value: 18937
- Attribute ID: 0x0a (Spin Retry Count ),
Raw Value: 0
- Attribute ID: 0x0b (Calibration Retries ),
Raw Value: 0
- Attribute ID: 0x0c (Power Cycle Count ),
Raw Value: 259
- Attribute ID: 0xc0 (Emergency Retracts ),
Raw Value: 252
- Attribute ID: 0xc1 (Load/Unload Cycles ),
Raw Value: 71
- Attribute ID: 0xc2 (Temperature Celsius ),
Current Value: 101 (Always Passing ),
Raw Value: 51
- Attribute ID: 0xc4 (Reallocation Events ),
Current Value: 188 (Always Passing ),
Raw Value: 12
- Attribute ID: 0xc5 (Pending Sectors ),
Raw Value: 271
- Attribute ID: 0xc6 (Uncorrectable Reads ),
Raw Value: 271
- Attribute ID: 0xc7 (CRC Errors ),
Raw Value: 0
- Attribute ID: 0xc8 (Write Error Rate ),
Raw Value: 264
Disk 1 ( 0, 1): ST4000NM0035-1V4107
10/06/2026 11:30:36 PM
SMART ATTRIBUTES: Version 10
Current Value: 084 (Always Passing ),
Raw Value: 232241071
Current Value: 095 (Always Passing ),
Raw Value: 0
Current Value: 099 (Always Passing ),
Raw Value: 1789
Raw Value: 0
Current Value: 092 (Always Passing ),
Raw Value: 1635987678
Raw Value: 22729
Raw Value: 0
Raw Value: 276
- Attribute ID: 0xbb (Reported Uncorrect ),
Current Value: 070 (Always Passing ),
Raw Value: 30
- Attribute ID: 0xbd (High Fly Writes ),
Raw Value: 0
- Attribute ID: 0xbe (Airflow Temperature ),
Current Value: 051 (Always Passing ),
Raw Value: 825229361
Raw Value: 210
Current Value: 045 (Always Passing ),
Raw Value: 111698
Current Value: 049 (Always Passing ),
Raw Value: 49 (0 17 0 0)
- Attribute ID: 0xc3 (Recovered ECC Errors ),
Current Value: 001 (Always Passing ),
Raw Value: 0
Raw Value: 0
Raw Value: 0
October 7th, 2026, 0:43
SWM wrote:You cannot write to this disk or run CheckDisk. The data will be corrupted.
October 7th, 2026, 7:24
October 7th, 2026, 7:39
Jonny_Quick wrote:Disk 0 ( 0, 0): WDC WD4000FYYZ-05UL1B0
Current Value: 187 (Always Passing -),
Raw Value: 422
Raw Value: 12
Raw Value: 271
Raw Value: 271
October 7th, 2026, 8:10
October 7th, 2026, 11:35
SWM wrote:This drive is faulty. 422 reallocated sectors, 271 pending write-reallocation, and an unknown number more unidentified.
SWM wrote:The previous message meant that as soon as Windows sees a partition, it begins writing to it at its own discretion.
October 7th, 2026, 18:02
Does "faulty" mean non-repairable?
I've looked over several SMART logs and it all seems meaningless to me.
Attribute Raw value
05 Reallocated sectors 422
C4 Reallocation events 12
C5 Pending sectors 271
C6 Uncorrectable sectors 271
C8 Write errors 264
Finally, I'm also wondering about what happens to the data if the one good HD can no longer be accessed as part of a RAID array?
motherboard died for some reason, the data on the two RAID HDs would be lost forever?
October 7th, 2026, 18:11
October 8th, 2026, 18:56
No. The "bad" status was determined based on a large number of already reallocated sectors and a slightly smaller number of sectors pending reallocation. Another indicator that most likely wasn't taken into account by the software, but for Western Digital hard drives it is more than significant - write errors. Ideally, this value should be zero or very close to it, certainly not in the hundreds or thousands. This value indicates that the drive is damaged and will soon fail.I'm stuck on the idea that the reason why the HD is "bad" is due to the 16 uncorrectable sectors
October 8th, 2026, 22:29
ora wrote:No. The "bad" status was determined based on a large number of already reallocated sectors and a slightly smaller number of sectors pending reallocation. Another indicator that most likely wasn't taken into account by the software, but for Western Digital hard drives it is more than significant - write errors. Ideally, this value should be zero or very close to it, certainly not in the hundreds or thousands. This value indicates that the drive is damaged and will soon fail.I'm stuck on the idea that the reason why the HD is "bad" is due to the 16 uncorrectable sectors
Of course, you can ignore all the warnings, but the result will be the hard drive being dropped from the array due to extremely slow performance and data errors - and this will likely go unnoticed, as the status will remain "critical." From now on, the array will only work on the single remaining disk; if it fails, you will lose data.
I don't know how to rebuild the array on this motherboard, so I can't advise you on that, but another thing you should pay attention to is the hard drive temperatures.
Raw Value: 51
Raw Value: 49
Temperatures above 40°C are considered undesirable, and continuous operation at 50–60°C significantly shortens the drives' lifespan - this has been proven in practice. It would be worth considering some form of cooling.
October 12th, 2026, 13:33
WebClaw wrote:we care about this:
- Code:
Attribute Raw value
C8 Write errors 264
WebClaw wrote:I would strongly suggest you just keep things simple. Turn on RAID, go back to critical and use the previously provided instructions to rebuild the array with a new disk.
