 Post subject: wd5000LUCT-62MPJY0 Donor drive not found
PostPosted: October 11th, 2026, 6:26
I have a WD that needs a head replacement. I was searching for days on ebay, but unfortunately, I couldn't find this drive.
Most of the drives I found are WD5000LUCT-63RC2Y0.
Any suggestions on where I can buy a donor drive, please
Thank you for your help.
 Post subject: Re: wd5000LUCT-62MPJY0 Donor drive not found
PostPosted: Yesterday, 2:28
Suffix alone isn't enough for a head swap; the DCM code (pos 5-7) and date are critical.
If you post your drive's label photo or DCM code, other members or I can help check if there are compatible donors on the market.
Users browsing this forum: No registered users and 56 guests
