 Post subject: What Does "MTBF" (Mean Time Before Failure) Actually Mean?
PostPosted: October 14th, 2026, 12:28
I'm shopping for a Hard Drive and noticed on the specifications that one of the drives claims it has "2 million hours" of MTBF, and so I take 2,000,000 divided by 24 hours equals 83,333 days divided by 365 days (in a year) equals 228.3 years, and yeah I call bullshit, because there is NO WAY that any hard drive is going to last 228 years.
So, then what does it mean, and how long will a hard drive last that is spec'd at "2 million hours"?
 Post subject: Re: What Does "MTBF" (Mean Time Before Failure) Actually Mea
PostPosted: October 14th, 2026, 14:37
It is the average time between failures in a large population of drives. In your example, a population of 1000 drives can expect a failure every 2000 hours (2 million hours / 1000).
PostPosted: October 14th, 2026, 15:10
https://en.wikipedia.org/wiki/Mean_time ... n_failures
Helium disks have more platters as the friction is lower. Servers with millions of disks can use MTBF to estimate how many spare drives will be needed before a forklift upgrade is needed.
PostPosted: October 14th, 2026, 19:37
Hardcore Games wrote:
https://en.wikipedia.org/wiki/Mean_time_between_failures
Not sure how upgrading server with forklifts would work... is this because they 'hold' more data? or because you 'drive' a foklift? Storage on Pallets instead of platters is an interesting Idea, but I have not heard of drives coming from CHEP or Loscam as yet. Also would be quite cumbersome for a home user. Bunnings could store a lot on their shelves, maybe they are the next Data Centre?
PostPosted: October 17th, 2026, 13:32
Which, according to my 8th grade math means that 2 million hours PER DRIVE is average, and that some get less and some get more. I don't see why the point of the thread had to be clouded with the introduction of a "million" drives (multiplying both sides of an equation by a million) and then reducing the number to 2,000 hours out of those million drives. Multiply by a million, then divide by a million, "TA DAH! Lookit what I did, aren't I clever."
Yeah, no. Point was clearly made that I think the 2 million hour average time for failures is bullshit. Made up. False. Lie. Marketing horseshit. Unless someone knows something I'm missing, because I think it's 100% bullshit. Take a 2 million hours, divide by 24 hours, then divide by 365 days in a year means that on average a drive lasts 228 years. Complete bullshit. Now multiply that 228 years by a million hard drives, then divide by the number of hard drives and PRESTO! it's 228 years. Utter horseshit.
Why is it that I'm on HDD Guru, THE place online where you find supposed "experts" in hard drives and they pull rabbits from hats, multiple by a million, then divide by a million, wave a magic wand, shout "ABRACADABRA", and then stand around proud of themselves like they just DID SOMETHING, and somehow magically have the illusion that they KNOW SOMETHING that the general public might not know. Meaning it's not just the MTBF factor that's utter horseshit, but it's the supposed "answer" to my question that is also horseshit. If I wanted a retarded, low-IQ and dumbed down response to my question, I would have asked ChatGPT or the nearest Somalian.
Unless I'm missing something, and if so, what is it?
PostPosted: October 17th, 2026, 17:17
MTBF actually reflects drive.hours, not hours. It reflects the total operating time of a population of drives.
MTBF does not remain constant throughout the entire life of a drive. That should be obvious to anyone with at least two neurons. At 10 years, the MTBF could fall to 20000 drive.hours rather than 2 million, in which case a population of 1000 10-year-old drives would be failing every 20 hours.
PostPosted: October 18th, 2026, 9:36
Just ignore it, as it's obvious that a single hard drive won't last millions of hours, no matter how you fiddle with the numbers.
It's the same with gigabytes on a sticker. You buy a drive with 4 terabytes written on it in huge letters, you plug it in, and it says 3.5 terabytes. They might even write on your hard drive in smaller letters that 1 gigabyte is 1 billion bytes, but you expect to see 4 terabytes where you see 3.5, and that's not what you paid for! And there's plenty of this kind of "honest" deception going on around the world.
At best, a hard drive will last 40,000-50,000 hours, but if you get a defective one, it won't even last a year, but that's what you have a warranty for.
The hard drives currently being produced and sold are of roughly the same quality. In the past, there were problems with certain series of hard drives, with one in four failing within a very short time (a few months or a little over a year), but that's no longer the case.
PostPosted: October 18th, 2026, 10:00
MTBF is a figure that results from the annualised failure rate (AFR).
    AFR = 1 year / MTBF x 100% = 8766 hours / 2 million hours x 100 = 0.438%
The real AFR figures compiled by BackBlaze are about 4 times higher, so their actual MTBF is 500K hours.
Let's say you have a population of 1000 new drives. After one year let's say that 4 have failed.
    MTBF = total drive.hours / number of failed drives = 1000 x 8766 / 4 = 2.2 million hours
PostPosted: October 18th, 2026, 18:37
Vendor marketing statistics are either Bullshit or Horseshit. They are essentially the same thing, but horseshit can sometimes have a use if you sprinkle enough of it around.
There is no way anyone, not even the vendor will know how many will fail, and even less likely to be able to tell which ones no matter what the test. The general population don't care about exact specs, nor understand them. The data HAS to be dumbed down. You have to say SOMETHING... when you buy a 4TB disk and it reports 3.5TB, that IS what you pay for. The Spec data is there, it is not deception. Motorcycles are commonly rated as, for example a 100, 250, 500.. but their engine capacity is actually say 249CC labelled as a 250. Things cost us $5 but are $4.99. There may be only 2 people on the planet in any given week even trying to understand what MTBF means!
not sure how fzabkars answer was dumbed down when it explained exactly what it means
PostPosted: October 18th, 2026, 20:53
Well, I did it, and I wouldn’t say that ChatGPT gave a worse answer than a real person. Ask the machine the right questions and you will get the right answer. Yes, it missed some things that a person who held a hard drive in his hands and had real experience in using it knows, and could not find the proposed datasheet on the Seagate website and read in it that that particular model is an SMR hard drive that is not worth buying, and it has not a 3-year warranty, but 2, but it did not offer it for purchase in the end. It only recommended Toshiba and Western Digital.
All the answers together, therefore, the machine gave in less than 20 seconds. I spent a lot more asking questions and taking a screenshot...
https://i.ibb.co/1Gd4xdCT/e00.png
PostPosted: October 18th, 2026, 21:09
I would say with lots of things it is
Tell the machine the right Answers and you will get the right answer.
or
Ask the machine questions and you will get answers.
or
Ask the machine the right questions and you will get something that sounds like the right answer.
But often it does help you flesh something out from a starting point and get somewhere quite further in a very short amount of time.
PostPosted: Yesterday, 16:19
I would be curious if there's any statistics on what the average lifespan for drives is from a power on hours (spinning), start stop, or load/unload standpoint. Despite the one off failures that can happen at any time, I think modern drives are actually more reliable than we give credit for. It's not uncommon for drives to be hitting 100K+ power on hours or even in my case, 50K+ start/stop cycles. There really doesn't seem to be any real evidence that starting and stopping drives regularly (within a reasonable amount), has any negative affects on lifespan.
PostPosted: Yesterday, 17:00
There was a recent discussion at Reddit involving a HDD reliability study. The study concluded that HDDs are becoming more reliable. However, the study was flawed insofar as the authors failed to recognise that WD HDDs were actually native HGST models, and at least one Toshiba model was also a native HGST.
Are There Manufacturer Differences in Hard-Drive Reliability?
https://arxiv.org/pdf/2606.29078v1
The study used statistics provided by Backblaze.
Here are 6 sets of annual stats:
https://backblazeprod.wpenginepowered.com/wp-content/uploads/2021/01/Drive-Stats-2020-2020-Table-1.jpg
https://backblazeprod.wpenginepowered.com/wp-content/uploads/2022/01/7-chart_2021_lifetime_AFR.png
https://backblazeprod.wpenginepowered.com/wp-content/uploads/2023/01/7-Lifetime-chart-for-2022.jpg
https://backblazeprod.wpenginepowered.com/wp-content/uploads/2024/02/4-Lifetime-AFR-670x1024.png
https://backblazeprod.wpenginepowered.com/wp-content/uploads/2025/02/2-Annual-AFR-table-for-2024.png
https://backblazeprod.wpenginepowered.com/wp-content/uploads/2026/02/Q4-2025-Drive-Stats-Quarterly-1536x1397.png
All the WDC drives have a WUH prefix. These are rebadged HGST helium models.
For example, here is a WUH721816ALE6L4:
https://img.alicdn.com/bao/uploaded/i4/84065273/O1CN01lYUP281op5FU7SLaZ_!!84065273.jpg
Its WWN is 5000CCAnnnnnnnnn. This is a HGST WWN. A WDC WWN would be 50014EEnnnnnnnnn. The drive is an Ultrastar which is a HGST model series. The part number is 0F38466, which is a HGST p/n.
In short, there are no native WDC drives in the stats for 2020-2025.
This chart has 3 native WDC models -- WD30EFRX, WD40EFRX, WD60EFRX. These have some of the highest failure rates, between 3 and 6 times higher than HGST.
https://backblazeprod.wpenginepowered.com/wp-content/uploads/2020/02/Blog_3_year_Drive_Stats_Chart.png
There are 3 Toshiba models in these stats:
https://backblazeprod.wpenginepowered.com/wp-content/uploads/2016/02/blog-drive-model-stats.png
The worst figure is for a DT01ACA300. This is a rebadged HGST HDD. It was marketed for consumer desktop computers:
https://toshiba-semicon-storage.com/content/dam/toshiba-ss-v3/master/en/storage/product/internal-specialty/cHDD-DT01ACAxxx-product-overview_EOL.pdf
PostPosted: Today, 9:21
What good are these statistics really? As soon as someone buys them and puts them into service, they are putting them into a totally different environment than what the statistics were based on. They are also likely a different batch. You may somehow find the drives that data shows will last the longest, and it shits itself due to a MB issue, power spike, cat peeing on it, lightning, Firmware bug, mistreatment or just plain gremlins. You also have wasted many hours. Pick a reputable drive based on one available to you that people on the net haven't complained about and sort your backup solution. I don't know why, but pissing about with statistics of storage really grinds my gears.. it isn't you, it's me
PostPosted: 36 minutes ago
From the study, similar drives operating at similar temperatures showed different failure rates in different cluster locations:
In addition, the effect of HDD position in the data-center matters. While accounting for HDD position does not change estimates of HDD manufacturer differences (see Table II), there are still large differences between clusters in terms of hazard rates. Specifically, the cluster-specific estimates of the regression in column 1, Table II suggest that cluster 20 with the highest failure rates almost has 1.287/0.489 ≈ 2.63 times the failure rates of cluster 60 with the lowest failure rates – for HDDs with the same manufacturer, capacity, age, form-factor, and temperature.
Users browsing this forum: ghu112 and 98 guests
