KALOK lba0
March 27th, 2015, 12:14
Hello guys
I have a KALOK KL3120 that i cant seam to get user data access. The drive is detected in pc3000 with o capacity .
I have no experience with this kind of drives
Thank you all for sharing
Re: KALOK lba0
March 27th, 2015, 12:19
Wow!
This is an old drive. :wink:
Is the data important?
Re: KALOK lba0
March 27th, 2015, 12:20
AdrianSRD wrote:Hello guys
It might seam strange but its really important, i don't know how nowadays someone can still use this kind of drives
Re: KALOK lba0
March 29th, 2015, 18:39
AdrianSRD wrote:It might seam strange but its really important, i don't know how nowadays someone can still use this kind of drives
Boeing designed their 757/767 aircraft on a CAD/CAM minicomputer with an 80MB SMD. Later versions of the machine had 300MB HDDs. My first data recovery (during the late 1980s) was on one of these drives.
In 1969 NASA sent astronauts to the moon with a computer that had the power of a Commodore 64. Nowadays any advances in hardware technology are quickly eroded by lazy programmers and web designers. What Intel giveth, Microsloth taketh away.
Re: KALOK lba0
March 29th, 2015, 18:44
I love old tech, so I just had to find out how it all works. :-)
Kalok KL3120 120MB IDE drive
KL-3120 OEM Manual:
http://archive.hmvh.net/txtfiles/hdd/KL3120.MAN.txt
    Cylinders 981
    Sectors/track 40
    Heads 6
PBL3772, ERICSSON, Dual Stepper Motor Driver, 28-pin power PLCC, 1A per channel:
http://pdf.dzsc.com/PBL/PBL3772.pdf
http://pdf.eepw.com.cn/p20091012/7f0acc ... 1a0f35.pdf
PBM3960, ERICSSON, Microstepping Controller/Dual Digital-to-Analog Converter, 28-pin power PLCC:
http://pdf.datasheetarchive.com/datashe ... 175180.pdf
HY62256ALJ-10, Hyundai, 32K x 8bit CMOS SRAM, 5V:
http://www.romstore.ru/pdf/HY62256.pdf
Z08691-12VSC, Zilog, Z8, ROM-less, 8-bit microcontroller, 12MHz, Full-Duplex UART; 2 Counter/Timers:
http://www.americanmicrosemi.com/inform ... 8691-12PSC
Z86C91, Zilog, Z8, ROM-less, 8-bit microcontroller, 12MHz, Full-Duplex UART; 2 Counter/Timers:
http://ixapps.ixys.com/DataSheet/ps0185.pdf
F82C5059, Chips & Tech, Single Chip PC/AT Disk Controller:
http://www.datasheetarchive.com/dl/Scan ... 076750.pdf
http://pdf.datasheetarchive.com/datashe ... 053823.pdf
HA13471A, Hitachi, 2A, three-phase motor drive with speed discriminator, Hall amps:
http://pdf.datasheetarchive.com/datashe ... 249737.pdf
XR541CJ, Exar, Disk-Tape Support Circuit - Hard Disk Pulse Detector, 3ns Pulse Pairing:
http://pdf.datasheetarchive.com/indexer ... 047321.pdf
XR532ACJ, Exar, Disk-Tape Support Circuit - 7.5 to15Mb/sec RLL(2,7) Data Synch/Sep & ENDEC:
http://pdf.datasheetarchive.com/indexer ... 036386.pdf
stepper motor, Sanyo Denki Co. Ltd
    103-4902-12T1
    73009-001
    4.3 ohm
    0.9 deg/step (400 steps per rev)
Possible preamps (for 6 heads) - XR-117, XR-501, XR-511
XR-117/117R, Exar, R/W Preamplifier for 3 Terminal Recording Heads, 2, 4, or 6 Channels:
http://pdf.datasheetarchive.com/indexer ... 047318.pdf
XR-501/501R, Exar, R/W Preamplifier for 3 Terminal Recording Heads, 6 or 8 Channels:
http://pdf.datasheetarchive.com/indexer ... 047311.pdf
XR-511/511R, Exar, R/W Preamplifier for 3 Terminal Recording Heads, 4, 6 or 8 Channels:
http://pdf.datasheetarchive.com/indexer ... 047314.pdf
Re: KALOK lba0
October 21st, 2026, 4:49
Hi To all Old Friends!
I’m looking for a high-resolution photo of the Kalok KL3100 hard drive controller to verify the values ​​of a few resistors:
R2, R6, R19
I want to restore the PCB and try to get this hard drive running.
(Most likely, a photograph of the KALOK KL3120 will also be suitable.)
Kalok KL3100
Re: KALOK lba0
October 23rd, 2026, 8:52
Ugh... those Kalok Octagon drives weren't exactely known for being reliable... check here: https://www.redhill.net.au/d/20.php
