ST3808110AS
October 27th, 2026, 11:08
ST3808110AS
Need ldr (7200.9 Tonka2)
3.ADJ
Thanks in advance.
Re: ST3808110AS
October 27th, 2026, 12:10
Found it on hddsurgery fw database.
But the problem still, and I get ATA ovl address failure.
Any suggestions?
Thanks in advance
Re: ST3808110AS
October 27th, 2026, 12:26
4096k x 16 SDRAM
TONKA2 - 1_Disk M-31 03-22-06 10:53
Head Mask FFFF - Switch to full int.
Spin Ready
(P)SATA Reset
DiskAccess ReadSector EC=43 at ffffffff.00.0002
12FFLUSH-1 Fail
CE Log ErrCode=0 LBA=0 Type=aDiskAccess ReadSector EC=43 at ffffffff.00.0059
Failed sys sect. write! Nwt Er 33 RdWr 15d5f.00.0007
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write! Nwt Er 00 RdWr 15d5f.00.0007
Initializing SMART SectorsFailed sys sect. write! Nwt Er 33 RdWr 15d5f.00.0007
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write! Nwt Er 00 RdWr 15d5f.00.0002
Unable To Load Overlay 01|000A
Re: ST3808110AS
October 27th, 2026, 12:29
I can read user sectors via terminal, but it's very slow.
Re: ST3808110AS
October 27th, 2026, 16:05
Is anything readable from the SA? Either the heads (surface) are dead, or someone formatted it with an m0... format. :)
Writing to the SA can be forced (1>F), but that might worsen the user data situation.
Re: ST3808110AS
October 28th, 2026, 9:20
SWM wrote:Is anything readable from the SA? Either the heads (surface) are dead, or someone formatted it with an m0... format. :)
Problem solved after uploading ovl to memory and cloning with 3mb/s via mrt utility.
Thanks.
