ST12000NM001G
October 28th, 2026, 9:23
Hello
Drive in topic (Evans-EXOS) came with 11x12 TB similar drives in QNAP (Raid 5)
All sectors shows ABRT.
NVC Format Corrupt.
Any suggestions?
Re: ST12000NM001G
October 28th, 2026, 10:03
Can you upload the ROM dump(s)?
Re: ST12000NM001G
October 28th, 2026, 10:16
fzabkar wrote:Can you upload the ROM dump(s)?
Sure, thanks in advance
Uploaded patient and one of the working drives (Raid members)
Patient.rar
(238.68 KiB) Downloaded 26 times
Working Raid member.rar
(258.32 KiB) Downloaded 25 times
Re: ST12000NM001G
October 28th, 2026, 10:26
I think those PCBs have two ROMs in a RAID configuration. Your patient dump has no NvC component.
Also, your dumps seem to be twice as large as they need to be. The second half of each dump is empty.
Re: ST12000NM001G
October 28th, 2026, 10:33
fzabkar wrote:I think those PCBs have two ROMs in a RAID configuration. Your patient dump has no NvC component.
That's true.
Must use advanced method to unlock.
Re: ST12000NM001G
October 28th, 2026, 10:37
I comapred two ROMs from two working drives and they seems fine. And I noticed a lot of differences in different places when compared to the patient ROM
Re: ST12000NM001G
October 28th, 2026, 10:39
Here's another dump from another working drive
Another working member.rar
(259.62 KiB) Downloaded 27 times
Re: ST12000NM001G
October 28th, 2026, 11:48
The NvCache area is located at 0xA0000 in your working dumps. Your patient dump is empty. How can the NvC be corrupt if it hasn't yet been created??
Re: ST12000NM001G
October 28th, 2026, 13:05
If you need a PCB, avoid this seller:
https://www.harddrivesdirect.com/products_image_large7.php?products_id=731675_ST12000NM001G
https://www.serverpartsdirect.com/images_large/sea_SATA_3_bottom.jpg (AI generated PCB, very very weird)
https://www.serverpartsdirect.com/images_large/ST4000NM0034_4.jpg (AI generated label, wrong model number in file name)
Re: ST12000NM001G
October 28th, 2026, 21:42
fzabkar wrote:If you need a PCB, avoid this seller:
no no... they can now print the PCB's in 8K... The chip names look like Russian Klingon ;-)
"BART NUMBER" SERIAL NUMEER"
just think that in a few years, AI will be choosing our medication and administering it with no human contact...
Re: ST12000NM001G
October 29th, 2026, 10:49
Re: ST12000NM001G
October 29th, 2026, 10:50
Or maybe worse.
Re: ST12000NM001G
October 29th, 2026, 10:51
Problem temporarily solved and I could clone the drive.
Re: ST12000NM001G
November 1st, 2026, 2:42
oh
https://www.cnet.com/tech/services-and-software/woman-died-after-chatgpt-advised-her-to-stop-taking-medication-lawsuit-alleges/
