ST31000528AS - PCB Replacment
November 5th, 2026, 10:17
Hi i have
Seagate ST31000528AS - 1TB
Firmware: CC35
Date Code: 09437
The drive does not power on at all, but the cause is clear.
I managed to read and extract the ROM from the drive. However, the only drive I could find locally is marked as follows
Firmware: CC38
Date Code: 10207
My question is: would this drive be a suitable donor?
Re: ST31000528AS - PCB Replacment
November 5th, 2026, 10:29
PCB # - and more importantly the MCU should match.
November 5th, 2026, 10:47
im find the board on ali:
100536501 REV A
The same MCU
it seems like things will be okay
https://pl.aliexpress.com/item/10050115 ... in_prod%3A
It looks bad, but it could be salvageable. Remove the shorted diode and run a wire from the SATA power connector to the diode's cathode ("v" on PCB).
Scrape off the carbonised area with a scalpel. It's conductive.
